Hello @Zeke and @DarrenWiens2 ,
I am working on a similar script but instead of just listing the selection, I want to use it as a logical parameter for executing "Calculate Geometry Attributes" on a parcel polygon.
So far I have built a model which works OK, except I get a field character count warning 🙄 When I export the model as a python script (see python window for the model script), I get an error saying this:
File "<string>", line 6
def # NOT IMPLEMENTED# Function Body not implemented
SyntaxError: invalid syntax
# -*- coding: utf-8 -*-
Generated by ArcGIS ModelBuilder on : 2021-09-17 08:27:10
import arcpy
def GeometryCalc(): # GeometryCalc
# To allow overwriting outputs change overwriteOutput option to True.
arcpy.env.overwriteOutput = False
arcpy.ImportToolbox(r"c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Data Management Tools.tbx")
# Model Environment settings
with arcpy.EnvManager(scratchWorkspace=r"C:\Users\abishop\AppData\Local\Temp\ArcGISProTemp10544\1ba0f558-c873-4c6c-be6d-dc08393016c0\Default.gdb", workspace=r"C:\Users\abishop\AppData\Local\Temp\ArcGISProTemp10544\1ba0f558-c873-4c6c-be6d-dc08393016c0\Default.gdb"):
parcel = "I:\\users\\abishop\\DATA\\CadastreCopy.gdb\\parcel"
# Process: Select Layer By Attribute (Select Layer By Attribute) (management)
parcel_Layer, Count = arcpy.management.SelectLayerByAttribute(in_layer_or_view=parcel, selection_type="NEW_SELECTION", where_clause="GIS_ACRES IS NULL", invert_where_clause="")
# Process: If Selection Exists (If Selection Exists) ()
True_48, False_49 = # NOT IMPLEMENTED(in_layer_or_view=parcel_Layer, selection_condition="EXISTS", count=0, count_min=0, count_max=0)
# Process: Calculate Geometry Attributes (Calculate Geometry Attributes) (management)
if True_48:
parcel_Layer_2_ = arcpy.management.CalculateGeometryAttributes(in_features=parcel_Layer, geometry_property=[["GIS_ACRES", "AREA"]], length_unit="", area_unit="ACRES", coordinate_system="PROJCS[\"NAD_1983_StatePlane_Florida_West_FIPS_0902_Feet\",GEOGCS[\"GCS_North_American_1983\",DATUM[\"D_North_American_1983\",SPHEROID[\"GRS_1980\",6378137.0,298.257222101]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"False_Easting\",656166.6666666665],PARAMETER[\"False_Northing\",0.0],PARAMETER[\"Central_Meridian\",-82.0],PARAMETER[\"Scale_Factor\",0.9999411764705882],PARAMETER[\"Latitude_Of_Origin\",24.33333333333333],UNIT[\"Foot_US\",0.3048006096012192]]", coordinate_format="SAME_AS_INPUT")[0]
if __name__ == '__main__':
GeometryCalc()
Amanda Bishop, GISP
