Combine rows within table based on if there is any data populated- Using Python
741
04-26-2017 01:13 PM
BrianneStafford1
Basically I am focusing on 2 fields.
fields[0] = Apple
fields[1] = Grape
fields[2] = Pear
What I want in English:
If Apple has data and Pear has no data
      Pear =  Apple
If Grape has data and Pear has no data
   Pear = Grape
Otherwise: Pear = Pear
   *All 3 columns will never be populated, as well as Apple and Grape will never be populated simultaneously
I tried making up a script using Notepad ++ but it is not translating at all and the results are just reading the columns as their original data.
I know this is wrong but I do not know what would be right.
JoshuaBixby
Since Apple and Grape will never be populated simultaneously, and you only want to populate Pear if it has no data, the following should work in the Field Calculator expression (make sure to select Python parser):
(!Apple! or !Grape!) if !Pear! is None else !Pear!
The above is using a Python Conditional Expression, a.k.a., ternary operator.
DanPatterson_Retired
Based on you description, you have limited possibilities of combinations, hence, have a look at this to ensure that you aren't missing any possibilities
rows = [['A', None, None],
        [None, 'G', None],
        [None, None, 'P'],
        [None, None, None]
for row in rows:
    if row[2] is None:
        row[2] = [row[0], row[1]][row[0] is None]
    print("row... {}".format(row))
# which yields...
row... ['A', None, 'A']
row... [None, 'G', 'G']
row... [None, None, 'P']
row... [None, None, None]
DarrenWiens2
MVP Honored Contributor
At some point, you'll also have to change your fields list to include strings, not unspecified variables:
fields = ['Apple','Grape','Pear']
Also, you need to call the following to actually update the row:
cursor.updateRow(row)
