Compress PDFs with Python
438
05-11-2022 05:32 PM
AlfredBaldenweck
MVP Regular Contributor
Hi all,
I'm looking for a way to compress exported layouts beyond the "export as image" option. That is, I want to compress them a la the "Optimize" tool in Adobe Acrobat.
I've done some googling and it appears there may be some packages floating around to let me do it, but I was wondering if there was anything in the standard set of packages installed with Pro that would allow me to do this.
Thanks!
DanPatterson
Look at the python package manager within Pro and see if any of your googled packages are on the list.
... sort of retired...
AlfredBaldenweck
Hi Dan, I had actually checked there, as well as opening up .py files that looked promising (zip, anything with pdf in the name, etc.), prior to asking this here, but I just checked again to be sure.
My reason for asking is because I know frequently there's capability hidden in odd places that aren't readily apparent.
With that in mind, are there any packages that might be hiding similar capability?
