I have a cloned the default arcgispro-py3 conda environment and would like to set up vscode IDE and use it as my interpreter and in the terminal but am struggling with a few issues:
I can choose my default interpreter just fine by pointing to the python.exe inside my cloned conda environment, however the indicator at the bottom says (system) instead of (conda) - is that ok?
When I launch a terminal in vscode (or in Windows) it throws up error:
Warning:
This Python interpreter is in a conda environment, but the environment has
not been activated. Libraries may fail to load. To activate this environment
please see https://conda.io/activation
but when I run "conda activate myvenv" - the command states that myvenv is already the active environment...
I guess I'm looking for pretty explicit instructions on how to configure a cloned ArcGIS Pro python environment to work with vscode, Windows PATH considerations, etc. and am a little lost. There seem to be some differences between a regular Anaconda windows installation and the way Pro sets it up.
Possibly there is a guide that someone is aware of or if someone working in this IDE could chime in that'd be great.
