Converting Degrees to Meters from table, no Datum information
863
10-27-2021 04:23 AM
Vakhtang_Zubiashvili
Hi everybody,
I am trying to make python tool in ArcGIS desktop, where user can select row in e.g. excel table, that has written X and Y in next format X: 44.919644, Y: 41.691083. But i am using Meters (Projected Coordinate System: WGS_1984_UTM_Zone_38N, Geographic Coordinate System: GCS_WGS_1984
Datum: D_WGS_1984
) in my database and when i insert this points it goes somewhere at the edge of the world. I tried to add spatial_reference like this:
arcpy.da.SearchCursor("Watersupply_GWP.DBO.%GIS_ACCIDENTS",["PointCoordinateX","PointCoordinateY"], None, spatial_reference = 32638)as cursor:
but i get same result. One problem is that, i do not know Datum, these coordinates taken by Android tablet, so i have only coordinates and could not use projectAs() method.
Any help, idea appreciated.
Tomasz_Tarchalski
your table has no geometry, and you cannot apply convertion directly to fields within table. if you are using desktop and arcpy 2.7 you could do sth like that:
#create empty point object
point = arcpy.Point()
#define projection in /out
sr_in = arcpy.SpatialReference(4326)
sr_out = arcpy.SpatialReference(32638)
table_in ="my_table"
fields = ["PointCoordinateX","PointCoordinateY"]
with arcpy.da.SearchCursor(table_in, fields) as recs:
    for rec in recs:
        # set temporary point object
        point.X = rec[0]
        point.Y = rec[1]
        # create point geometry from point object
        pointGeometry_in = arcpy.PointGeometry(point, sr_in)
        # reproject, no transformation
        point_Geometry_out = pointGeometry_in.projectAs(sr_out)
        # print output
        print(point_Geometry_out.centroid.X, point_Geometry_out.centroid.Y)
Tomasz_Tarchalski
    for rec in recs:
        point.X = rec[0]
        point.Y = rec[1]
        # print output
Thank you Tomasz, you save me ❤️ I simply integrated your code in my code and now it works fine. Thanks
