Counting instances of non-zero fields in a record
3029
12
07-29-2016 11:49 AM
DavidFox
New Contributor III
Referring to the table snippet above, each record has five fields for the last five fiscal years. The data will be either the number of that year or zero.
I need to calculate the Burns_5Yrs field based on the count of the number of non-zero years (in fields FY11 - FY15) in that record. The first three rows have examples manually entered. For example, the first record has activity in FY11 and FY14 so the result for Burns_5Yrs should be 2. The second row is also 2 and the third row is 4.
I've been doing this manually but now I have a table with 198 records so I'd like a programming solution, preferably in Python. Any help would be appreciated as I really don't know where to start.
Dave
Tags (1)
JoshuaBixby
MVP Esteemed Contributor
The code block can be bypassed completely by using the sum() function directly in the expression block:
sum(1 for field in (!FY11!, !FY12!, !FY13!, !FY14!, !FY15!) if field)
DavidFox
New Contributor III
Thanks, this worked perfectly (after I used the actual field names instead of the aliases).
DanPatterson_Retired
Pandas was too clunky, so numpy in the field calculator... with pictures
The only thing to remember
  • always choose the python parser... and there is no way to set it to default
  • write a function... doesn't need to be fancy.
  • any imports are done once, so if numpy is already imported, it is only imported once
  • the function just contains the variables which will be used.  In this example, I used the field names without the ! marks.  There is no requirement for the variables to have the same field names
  • in the expression box, you put function name (ie 'r') plus the variables to pass.  The field names are being passed so enclose them in ! marks.
  • save your function for later use if you like
That's all
