CreateGPSDDraft with multiple results issue
1029
03-28-2013 09:11 AM
AlexanderKhoroshun
I'm trying to call CreateGPSDDraft function (new 10. SP1 ArcPy function) with multiple results parameter as described in this help topic:
http://resources.arcgis.com/en/help/main/10.1/index.html#//018v0000008z000000
toolOneResultFullPath = "C:/SCRIPTSTEST/ToolOneResult.rlt"
toolTwoResultFullPath = "C:/SCRIPTSTEST/ToolTwoResult.rlt"
arcpy.CreateGPSDDraft([toolOneResultFullPath , toolTwoResultFullPath ], "output.sddraft", "myservice")
But, I'm getting "Value Error: C:/SCRIPTSTEST/ToolOneResult.rlt" (Line 481 in "_base.py").
There's no errors if I'm calling  CreateGPSDDraft function with any single result.
Any advice from Esri team?
AlexanderKhoroshun
Unfortunately, it seems like CreateGPSDDraft function doesn't work with multiple results if results are taken from saved files.
The only workaround I was able to find it's run tools in Python script and get results 'on the fly'.
CreateGPSDDraft function works with multiple results I got in the script.
Hopefully this issue's going to be fixed because for some workflows it's necessary to run CreateGPSDDraft function with multiple saved results as parameter.
ShaneBuscher
ESRI?
