Creating folders help (python beginner)
804
6
02-23-2012 07:18 AM
chukwuemekaobilor
I am trying to create folders and each folder will have a name from a field in my grid layer.
My grid has 500 tiles and I need to create 500 folders.  The naming convention is like 001A1, 001A2,
001A3, 001B1, 001B2, 001B3, 001C1, 001C2, 001C3, 002A1...................
My code starts like this
import sys, string, os, arcgisscripting, traceback
gp = arcgisscripting.create()
env.workspace = "C:\Backup Files\Backup Files\GISPROJECTS\Python_Practice"
# Set local variables
output_folder_path= "C:\Backup Files\Backup Files\GISPROJECTS\Python_Practice"out_name = "folder1"
output_folder_name = foldername
# Execute CreateFolder
DarrenWiens2
MVP Honored Contributor
import os
os.mkdir("H:/newfolder") # makes folder "newfolder" on H:
chukwuemekaobilor
thanks, How can i have it create 500 folders with different names
DarrenWiens2
Use a Search Cursor to loop through the grid cells (I assume your grid is a grid of polygons...?) to get the cell's value. Then, inside the loop, incorporate the cell value into a path string, then use that string inside os.mkdir().
DanPatterson_Retired
this line will fail
either use double backslashes, a single foreslash or append an r to the beginning of the path
chukwuemekaobilor
thanks all.  I will start trying it out and see how it work.  definetly this is new to me but I will surely get it right.  thanks again
chukwuemekaobilor
yes it is a polygon
