data driven pages - check if true - arcpy
537
09-01-2013 11:40 PM
PeterMacKenzie1
New Contributor II
is there any code to check if an mxd has data driven pages activated?
e.g.
if datadrivenpages = true
   then xx
else
yy
XanderBakker
Esri Esteemed Contributor
Hi Peter,
In fact there is (at least in 10.1 and 10.2, I didn't check older versions). The arcpy.mapping.MapDocument has a property "isDDPEnabled":
    import arcpy     myMXD = r'C:\Project\_LearnPython\DDPwelaan.mxd'     mxd = arcpy.mapping.MapDocument(myMXD)     if mxd.isDDPEnabled:         # do something with Data Driven Pages         pass     else:         # do something else here         pass
Links:
http://resources.arcgis.com/en/help/main/10.1/index.html#//00s30000000n000000
http://resources.arcgis.com/en/help/main/10.2/index.html#//00s30000000n000000
http://resources.arcgis.com/en/help/main/10.2/index.html#/DataDrivenPages/00s300000030000000/
XanderBakker
Hi Peter,
Links:
PeterMacKenzie1
New Contributor II
Great, that worked. Thankyou!
XanderBakker
Hi Peter,
I'm glad that worked out for you. Could you click on the green check mark? See also the note below:
Did you post and someone replied with a good answer? Help the community  to find these great posts with answers by clicking the green check mark  to indicate that it has been answered for you.
Kind regards,
Xander
