Day of the year calculation in ArcPy syntax help
605
03-28-2019 08:08 AM
RyanHowell1
New Contributor III
I am trying to calculate a "day of the year" field in a feature class using ArcPy.
###create day update cursor
cursorD = arcpy.da.UpdateCursor(featureclass,["month", "day", "dayoftheyear"])
print("day cursor set")
###loop and assign day of the year
for updateRowD in cursorD:
    if 'month' == 1:
        print("Jan")
        "dayoftheyear" = [day]
        cursorD.updateRow(updateRowD)
        print("Jan completed")
    elif 'month' == 2:
        print("Feb")
        "dayoftheyear" = [day] + 31
        print("Feb completed")
    elif 'month' == 3:
        print("Mar")
        "dayoftheyear" = [day] + 59
        print("Mar completed")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
and continues throughout the rest of the year (April through December). I'm getting syntax errors on the lines where I actually calculate the day number (lines 9, 14, 19, etc). I just can't figure out the syntax to get it to read the value of a field (day), perform basic arithmetic on it, and assign it to another field (dayoftheyear). I've used lots of combinations of [day], "day", !day!, etc and haven't been able to find my answer in any documentation.
Thanks in advance for your time and suggestions.
DarrenWiens2
MVP Honored Contributor
Save yourself the heartache of dealing with dates semi-manually by relying on the datetime module, which will handle it in one line and deal with leap years:
from datetime import datetime
year = 2020
month = 2
day = 29
day_of_year = datetime(year, month, day).timetuple().tm_yday
print(day_of_year)
60
StephenM
Occasional Contributor II
I think the proper syntax is to access the fields using their indexes, as ordered in your fields list. For example:
	if updateRowD[0] == 1:
		updateRowD[2] = updateRowD[1]
	elif updateRowD[0] == 2:
		updateRowD[2] = updateRowD[1] + 31
	elif updateRowD[0] == 3:
		updateRowD[2] = updateRowD[1] + 59
del updateRowD
del cursorD‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
The del statements are used to clear potential locks on the targeted feature class. You might consider creating the cursor using a with statement so that locks are cleared automatically:
with arcpy.da.UpdateCursor(featureclass,["month", "day", "dayoftheyear"]) as cursorD:for updateRowD in cursorD:‍‍‍‍‍‍
		cursorD.updateRow(updateRowD)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
You may also want to revise your print statements, since they'll print at every row.
JoshuaBixby
MVP Esteemed Contributor
I suggest you read Accessing data using cursors—Help | ArcGIS Desktop  , it will help you understand how to work with cursors.  Second, are you three fields just numeric/integer?
DarrenWiens2
year = 2020
month = 2
day = 29
print(day_of_year)
60
