I'm trying to automate clearing an existing layer definition query and setting a new one. The code I wrote does successfully set the new def query, but it deactivates the old query rather than actually deleting it. The Layer class code sample 2 shows how it presumably would be done, but it doesn't actually delete it. ArcGIS Pro - Modifying Layer Definition query via ArcPY also essentially asks the same question, but it was never fully answered.
for map in aprx.listMaps():
lyr = map.listLayers("Zoning History")[0]
lyr.definitionQuery = None
lyr.definitionQuery = "CaseNumber = '" + case + "'"
I've tried setting it as None and "" - both result in deactivating rather than deleting the old query. It's not a showstopper, but it's kind of weird. If I change the def query again, it will overwrite the old-new query, but the old-old query (which was not set using ArcPy, if it matters) still remains present but inactive.
I started thinking about other scenarios, such as what if I wanted to deactivate rather than delete a query? I haven't found any documentation for how to do that properly (rather than unintentionally) with ArcPy.
