I am running Desktop 10.2.2. I have been using model builder for years, creating models and exporting them to Python to automate tasks. Recently, after a number of process failures due to broken connections, I have been trying to upgrade them to validate connections and results before continuing to the next steps. What I wanted to do was simply check that a feature class was not empty before attempting to process it. For test purposes I made a very simple model to check the row count on a polygon feature class and if it were greater than 0 copy it to a new feature class. If the count was 0 it should stop. Really simple.
As a model it worked perfectly, so I exported it to Python. That produced this:
# -*- coding: utf-8 -*-
# TestModel.py
# Created on: 2018-01-16 11:41:45.00000
# (generated by ArcGIS/ModelBuilder)
# Description:
# Import arcpy module
import arcpy
# Load required toolboxes
arcpy.ImportToolbox("Model Functions")
# Local variables:
TestData = "C:\\Testing\\TestGeodatabase.gdb\\TestData"
TestPolys = "C:\\Testing\\TestGeodatabase.gdb\\TestData\\TestPolys"
# Process: Get Count
arcpy.GetCount_management(TestPolys)
# Process: Calculate Value
arcpy.CalculateValue_management("%Row Count% > 0", "", "Boolean")
# Process: Stop
arcpy.Stop_mb("true", "FALSE")
# Process: Feature Class to Feature Class
arcpy.FeatureClassToFeatureClass_conversion(TestPolys, TestData, "TestPolys2", "", "SHAPE_Length \"SHAPE_Length\" false true true 8 Double 0 0 ,First,#,C:\\Testing\\TestGeodatabase.gdb\\TestData\\TestPolys,SHAPE_Length,-1,-1;SHAPE_Area \"SHAPE_Area\" false true true 8 Double 0 0 ,First,#,C:\\Testing\\TestGeodatabase.gdb\\TestData\\TestPolys,SHAPE_Area,-1,-1", "")
Of course, that failed due to the IOError "The toolbox file Model Functions was not found", so I deleted the portion
Now it generates this error:
File "C:\GeoProcessing\SWProcessingPythonSQL2\Scripts\TestModel.py", line 20, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\management.py", line 3808, in CalculateValue
raise e
ExecuteError: ERROR 000539: SyntaxError: invalid syntax (<expression>, line 1)
Failed to execute (CalculateValue).
Why, why, why can't Model Builder export Python code that actually works? What is the point of a WYSIWYG GUI that doesn't produce functional code?
So, something is wrong with the expression. What exactly would that be since it works in Model Builder? This should be easy. All I want to do is validate that there is data to process before processing it.
