Error when saving raster ouput using iterator item in the raster name
797
7
06-05-2012 12:21 PM
toddsams
I am running into this error: "ERROR 010093: Output raster format UNKNOWN is unsupported" while attempting to save an output raster from the extract by mask function. Code snippet is below:
Main = sys.path[0]
env.workspace = Main
MainFdr = Main + os.sep + "fdr_combo"
HucPolys = Main + os.sep + "polys"
env.workspace = HucPolys
HUCs = arcpy.ListFeatureClasses()
for HUC in HUCs:
    try:
        FDRpath = Main + os.sep + "fdr"
        FACpath = Main + os.sep + "fac"
        # Execute ExtractByMask
        FdrOut = ExtractByMask(MainFdr, HUC)
        # Save the output
        env.workspace = FDRpath
        FdrOut.save("fdr_" + HUC)
    except:
        print "error_" + HUC
        continue
It works if I remove the iterator item ID (+ HUC) from the save name. However, I need to keep this in as a unique identifier so I do not overwrite my previous output.
Does anyone have thoughts on how to resolve this?
NareshPai
Try:
"fdr_" + str(HUC)
--Naresh
toddsams
Thanks for the suggestion Naresh! However, I still receive the error.
Might you have another thought?
toddsams
I made a variable i = 1 outside the For loop
Then increased it by 1 (i = i +1) at the end of the for loop and then added "i" to "fdr_" as: "fdr_" + str(i)
This worked.
(Although, it would be better if they were named with the value for whichever HUC was being operated on!!!)
toddsams
NareshPai
I would examine the hydrological unit codes closely. In the for loop, try putting:
print str(HUC)
to see if anything looks unusual.
Naresh
MarcinGasior
I suppose that your polygon features are in shapefiles.
If so, the HUCs variable contains list of shapefiles names with extension.
That's why script cannot create raster with .shp extension:)
To fix this, just remove ".shp" from the string (and make sure that composed name do not exceed 13 character length):
FdrOut.save("fdr_" + HUC[:-4])
toddsams
Indeed they ARE shapefiles, and YES that makes complete sense! I normally work with feature classes, so have not run into this problem before.
Many thanks.
