export to jpeg loop
2962
03-30-2012 05:23 AM
ReneSchulenberg
I created a loop to zoom to every shape in a shapefile and export that particular extent. The only problem is that the jpeg is given the number of the row as name. I want to give it the name of a field in de dbf. Does anybody have an idea how to do that?
import arcpy
from arcpy import env
from arcpy import mapping
mxd = arcpy.mapping.MapDocument(r"C:\gisbestanden\pythontest\test13.mxd")
df = arcpy.mapping.ListDataFrames(mxd)[0]
fc = r"Z:\kaarten\COROP\coropmultipart.shp"
count = str(arcpy.GetCount_management(fc))
x = 0
while x < int(count) + 1:
    rows = arcpy.SearchCursor(fc, "fid = " + str(x))
    for row in rows:
        xmin = row.shape.extent.XMin
        ymin = row.shape.extent.YMin
        xmax = row.shape.extent.XMax
        ymax = row.shape.extent.YMax
        newExtent = df.extent
        newExtent.XMin, newExtent.YMin = xmin, ymin
        newExtent.XMax, newExtent.YMax = xmax, ymax
        df.extent = newExtent
        mapping.ExportToJPEG(mxd, r"C:\gisbestanden\pythontest\gemeentekaart\JPEG_" + str(x) + ".jpg")
        print "successfully printed JPG"
    x += 1
curtvprice
MVP Esteemed Contributor
This is done the same way you accessed the shape field:
import arcpy
x = 0
    for row in rows:
        # get the field contents to name the file
        filename = row.getValue("NAMEFIELD") # or: row.NAMEFIELD
        # use the field contents in the filename
             r"C:\gisbestanden\pythontest\gemeentekaart\JPEG_{0}.jpg".format(filename))
    x += 1
curtvprice
import arcpy
x = 0
    for row in rows:
    x += 1
nathanbush
Hi Curtis,
I'm new to Python, but this is exactly what I need to do - run through my shapefile (poly) and zoom to each polygon within and export to JPEG. I've copied your script, but keep getting the attribute error 'Extent' object has no attribute 'Xmin'. My shapefile consists of 4 fields (FID, Shape, Unit, Hectares), am I missing something?
Nate
ReneSchulenberg
thanks for the quick reply! It worked!!
