Hi I'm using ArcPro 3.0. and using arcpy to export a chart following on from a script used to produce scores at the start of the script I have set the environment. However, when I try to export chart to SVG I get a Permissions error that I can't find any guidance on. Any help much appreciated.
c = arcpy.Chart('bar_final_scores')
c.type = 'bar'
c.title = "Final HBRA Scores for AU"
c.xAxis.field = 'Criteria'
c.xAxis.title= "Criteria"
c.yAxis.field = 'Score'
c.yAxis.title = "Score"
c.bar.aggregation = ''
c.dataSource = 'AUFinal'
c.exportToSVG('bar_final_scores.svg')
File "<string>", line 12, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\charts.py", line 448, in exportToSVG
with _codecs.open(path, "w", "utf-8") as f_svg:
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\codecs.py", line 905, in open
file = builtins.open(filename, mode, buffering)
PermissionError: [Errno 13] Permission denied: 'bar_final_scores.svg'
Best,
Chelsea
