Extracting List of Rasters By name
1156
8
02-25-2023 05:32 AM
AliTurabHani
Hi everyone. I am using Spyder and I have downloaded MODIS data from Earth Explorer and separated the daytime rasters using ListRasters(). Now I want to separate data from the different seasons and create a mean for 3 months, and for that I will have to use the image numbers( for e,g from 001 to 089 for Jan to March). I am not able to do so using ListRasters(), and can not find a solution online. I would appreciate any help in this matter. Please find below my code for reference:
import arcpy
import os
##Extract Daytime Temp from Terra Folder
arcpy.env.workspace = 'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Terra/'
os.mkdir('C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Terra_D/')
rootPath = 'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Terra/'
outputPath = 'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Terra_D/'
hdfList = arcpy.ListRasters()
for filename in hdfList:
arcpy.ExtractSubDataset_management(in_raster= rootPath + filename, out_raster= outputPath + filename[8:-29] + ".tif", subdataset_index= "0" )
##Extract Nightime Rasters from Terra
os.mkdir('C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Terra_N/')
outputPath = 'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Terra_N/'
arcpy.ExtractSubDataset_management(in_raster= rootPath + filename, out_raster= outputPath + filename[8:-29] + ".tif", subdataset_index= "4" )
##Extract Daytime Temp from Aqua Folder
arcpy.env.workspace = 'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Aqua/'
os.mkdir('C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Aqua_D/')
rootPath = 'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Aqua/'
outputPath = 'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Aqua_D/'
##Extract Nightime Rasters from Aqua
os.mkdir('C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Aqua_N/')
outputPath = 'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Aqua_N/'
##Create Mean for Day and Nighttime temps for Terra
arcpy.env.workspace ='C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Terra_D/'
Terra_D = arcpy.ListRasters("*", "TIF")
arcpy.env.workspace ='C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Terra_N/'
Terra_N = arcpy.ListRasters("*", "TIF")
os.mkdir('C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Terra_mean/')
from arcpy.sa import *
for (i,j) in zip(Terra_D,Terra_N):
outCellStats =CellStatistics([f'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Terra_D/{i}',f'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Terra_N/{j}'], "MEAN", "NODATA")
outCellStats.save(f"C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Terra_mean/{i}")
##Create Mean for Day and Nighttime temps for AQUA
arcpy.env.workspace ='C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Aqua_D/'
Aqua_D = arcpy.ListRasters("*", "TIF")
arcpy.env.workspace ='C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Aqua_N/'
Aqua_N = arcpy.ListRasters("*", "TIF")
os.mkdir('C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Aqua_mean/')
for (i,j) in zip(Aqua_D, Aqua_N):
outCellStats =CellStatistics([f'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Aqua_D/{i}',f'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Aqua_N/{j}'], "MEAN", "NODATA")
outCellStats.save(f"C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Aqua_mean/{i}")
##Create Mean for Daily Land Surface Temperature Of all four Rasters
os.mkdir('C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Daily_Mean/')
for (i,j,k,l) in zip(Terra_D,Terra_N,Aqua_D, Aqua_N):
outCellStats =CellStatistics([f'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Terra_D/{i}',f'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Terra_N/{j}', f'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Aqua_D/{j}', f'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Aqua_N/{k}' ], "MEAN", "NODATA")
outCellStats.save(f"C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Daily_Mean/{i}")
#Apply Scale Factor
arcpy.env.workspace = 'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Daily_Mean/'
rootPath = 'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Daily_Mean/'
os.mkdir( 'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Mean_K/')
outputPath = 'C:/Users/DELL/OneDrive/Desktop/ABD1/Map_Algebra/Ass1/DATA/Mean_K/'
rasterList = arcpy.ListRasters("*", "TIF")
for filename in rasterList:
output_raster = arcpy.sa.Raster(filename) * 0.02
output_raster.save(outputPath + filename)
2 Solutions
ChrisRingo
Can't you just build the list in python rather than using arcpy.ListRasters()? I.e., if your rasters were named as you suggested above, it would go something like this:
lstRasters = []
i = 1
while i < 90:
	if i < 10:
		rnum = "00" + str(i)
	else:
		rnum = "0" + str(i)
	lstRasters.append(os.path.join(Terra_D, "A2021" + rnum))
	i+=1
Then use lstRasters in CellStatistics. If you're working with 8-day MODIS averages rather than daily, then of course you'd modify the list index.
Unless I'm not understanding your question...
AliTurabHani
Yes that would also work as I just want to separate rasters 1 to 90, 90 to 180, and so on (only from the daytime rasters). Would you be kind enough to explain the above code ? How would I specify the output path ?
Yes I am working with 8 day MODIS averages. The first image is A2021001 and the next is A2021009 and so on. What do you mean by modifying the list index ?
DanPatterson
Please format your code and provide error messages
Code formatting ... the Community Version - Esri Community
... sort of retired...
AliTurabHani
Dear Sir,
I am not getting any error message in this code. This is just the previous code showing what I have done till now. Please find below the formatted code. I have mentioned each step in the code, and now I want to extract Daytime Values for the Months Jan to March. The filenames in my folder are in the format of "A2021001 ..... A2021002 ...... " and so on. I would appreciate any help in this issue. Thanks
import arcpy
import os
#Apply Scale Factor
DavidPike
MVP Frequent Contributor
you sure about your filepaths? linux or windows?
AliTurabHani
Hi David,
Yes my filepaths are correct, and I am working on windows. This code is working, and I am now trying to get the mean for the daytime rasters for the first 3 months of the year. The names of the files in the Terra_D folder are in the format "A2021001, A2021009" and so forth. I am trying to apply ListRasters() for  raster 001 to raster 089 only and get the mean and apply other statistics. Any help in this regard would be appreciated. Thanks.
ChrisRingo
lstRasters = []
i = 1
while i < 90:
	if i < 10:
	else:
		rnum = "0" + str(i)
	i+=1
AliTurabHani
ChrisRingo
Sorry, I didn't phrase that correctly - I meant the loop index, not list index - if you are using the 8-day MODIS, then you'd need to replace the last line with "i+=8" instead of "i+=1"
AliTurabHani
Got it. Thanks very much.
