Failed to execute (RastertoPolygon) Syntax error at or near symbol SPACE
4869
05-21-2015 03:30 AM
RobertBeno
I'm converting series of raster to polygon using RastertoPolygon in arcpy.
#import the module
import arcpy
from arcpy.sa import *
from arcpy import env
arcpy
.CheckOutExtension("Spatial")
env
.overwriteOutput = True
#set the workspace
env
.workspace = r"C:\thesis\for sampling\sampling_outputs\raster_per_biogeoregion"
#Get a list of rasters and convert to shapefile
for raster in arcpy.ListRasters("*Luzon_*.tif", "TIF"😞
print raster #check the presence of rasters
  arcpy
.RasterToPolygon_conversion(raster, raster.replace("tif", "shp"), "NO_SIMPLIFY")
print "Finish converting all the rasters to polygon"
After several checks on the syntax, formatting, I've always been stuck with this error:
Traceback (most recent call last😞
File "C:\Users\brentiebark\Dropbox\Python Scripts and mxds\batch_convert_raster_to_polygon_simple.py", line 14, in <module>
arcpy
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\conversion.py", line 178, in RasterToPolygon
raise e
ExecuteError: ERROR 010328: Syntax error at or near symbol SPACE.
ERROR
010267: Syntax error in parsing grid expression.
Failed to execute (RasterToPolygon).
XanderBakker
Esri Esteemed Contributor
Hi Robert Beno ,
Neil Ayres  suggestion might be right. Using spaces and special characters in paths might cause problems, especially when you use rasters.
When you post code, could you please use syntax highlighting for your code (see: Posting Code blocks in the new GeoNet ). If I copy your code and paste it into PyScripter it points out an error on line 14 where you are missing a space to indent the line and align the code with line 13.
Other observations:
  • you import the sa module, but you don't use it
  • you check out a spatial analyst extension but you don't use it
  • if the extension tif of a raster would be TIF, it will fail
NeilAyres
MVP Alum
Just a guess, can you remove spaces from your directory path and try again.
XanderBakker
Hi Robert Beno ,
Other observations:
SepheFox
Yes, it looks to me like line 14 is not indented properly. It should be consistent with the indenting for the print line above it.
