inList = [] for filename in rasterFiles: if filename.endswith('14'): inList.append(filename) arcpy.sa.CellStatistics(inList, outRaster, "MEAN", "DATA") # this line was incorrect in your example
# Import system modules import arcpy from arcpy import env from arcpy.sa import * # Check out the ArcGIS Spatial Analyst extension license arcpy.CheckOutExtension("Spatial") # Input data source arcpy.env.workspace = "S:/Work/Risa/Trial & Error/input" arcpy.env.overwriteOutput = True # Set output folder OutputFolder = "S:/Work/Risa/Trial & Error/output/" # Loop through a list of files in the workspace rasterFiles = arcpy.ListRasters() # Local variables: for filename in rasterFiles: print("Processing: " + filename) inRaster = arcpy.env.workspace + "/" + filename if filename.endswith("*.14.tif"): inRaster.append(filename) # Process: Cell Statistics outRaster = CellStatistics(inRaster, "MEAN", "DATA") # Save the output outRaster.save("S:/Work/Risa/Trial & Error/output/AvgPrecip01.tif") print "Average Calculated!!!"
# Import system modules import arcpy from arcpy import env from arcpy.sa import * # Check out the ArcGIS Spatial Analyst extension license arcpy.CheckOutExtension("Spatial") # Input data source arcpy.env.workspace = "S:/Work/Risa/Trial_and_Error/input" # don't use spaces or special characters in path names arcpy.env.overwriteOutput = True # Set output folder OutputFolder = "S:/Work/Risa/Trial_and_Error/output/" # Loop through a list of files in the workspace rasterFiles = arcpy.ListRasters() # The loop does nothing else but build the list inRasters = [] # you need to do this outside of the loop for filename in rasterFiles: print("Processing: " + filename) if filename.endswith("14.tif"): inRasters.append(filename) # Now we have a list of the files we want to average, but you only need to calculate the average once, # which means this part should not be in the loop, so we remove indentation outRaster = CellStatistics(inRasters, "MEAN", "DATA") # Save the output outRaster.save("S:/Work/Risa/Trial_and_Error/output/AvgPrecip01.tif") print "Average Calculated!!!"
# Import system modules import arcpy from arcpy import env from arcpy.sa import * # Check out the ArcGIS Spatial Analyst extension license arcpy.CheckOutExtension("Spatial") # Input data source arcpy.env.workspace = "S:/Work/Risa/Trial_Error/input" # don't use spaces or special characters in path names arcpy.env.overwriteOutput = True # Set output folder OutputFolder = "S:/Work/Risa/Trial_Error/output/" # Loop through a list of files in the workspace rasterFiles = arcpy.ListRasters() # The loop does nothing else but build the list inRaster = [] # you need to do this outside of the loop for filename in rasterFiles: print("Processing: " + filename) if filename.endswith("*.14.tif"): rasterFiles.append(filename) # Now we have a list of the files we want to average, but you only need to calculate the average once, # which means this part should not be in the loop, so we remove indentation outRaster = CellStatistics(rasterFiles, "MEAN", "DATA") # Save the output outRaster.save("S:/Work/Risa/Trial_Error/output/AvgPrecip18.tif") print "Average Calculated!!!" #takes the average and including the file that ends with *.14
Dear Darren,
Thank you very much for your reply. Maybe I said something wrong at the beginning. I want to include the files that ends with *.01 to *.12 but exclude *.14.
inRaster = [] # you need to do this outside of the loop for filename in rasterFiles: print("Processing: " + filename) if filename[-6:] in [str(x).zfill(2) + '.tif' for x in xrange(1, 13)]: rasterFiles.append(filename)
if not filename.endswith("*.14.tif"):
Or, just to be lazy:if not filename.endswith("*.14.tif"):
>>>filename = 'ppt_1970.14.tif' >>>filename.endswith('14.tif') True >>>filename.endswith('*.14.tif') False
