Help with Python Code/Field Calculator
426
7
03-28-2024 07:35 AM
BETAGIS
New Contributor II
Hi. I have a String Type field in a large attribute table. I want to add a "-0" a the end of each entry or "-1", "-2", etc. See examples below:
Example entries in this case would be:
CROOKED ST 1
CROOKED ST 2
CROOKED ST 3
CROOKED ST 4
CROOKED ST 5
CROOKED ST 6
CROOKED ST 7
CROOKED ST 8
CROOKED ST 9
CROOKED ST 10
How can I add the '-0' to the end of each entry so it'd look like:
CROOKED ST-01
CROOKED ST-02
CROOKED ST-03
CROOKED ST-04
CROOKED ST-05
CROOKED ST-06
CROOKED ST-07
CROOKED ST-08
CROOKED ST-09
CROOKED ST-10
Anyone know if this is possible? Even if I cant change the double digit values proceeding after the 10th entry it would be a great help.
Thanks!
AllenDailey1
Occasional Contributor III
Hello,
Here is a function / code block I wrote that does what you're describing:
def number_streets(street):
    components = street.split(" ")
    num = components[-1]
    if len(num) == 1:
        num = "-0" + num
    else:
        num = "-" + num
    stname = " ".join(components[:-1])
    result = stname + num
    return result
If you want to test it out, here's an example of how I tested it:
sts = ["MY ST 1", "MY ST 2", "MY ST 10", "MY ST 41"]
for st in sts:
    print(number_streets(st))
The results I got were:
MY ST-01
MY ST-02
MY ST-10
MY ST-41
For a field calculation, the expression would be:
number_streets(!YOUR_FIELD_NAME!)
I'd be interested to hear if you use this and/or if it works for your purposes.
MErikReedAugusta
Depending on a few things, you could do this with a regex calculation, or you can brute-force it.
  1. Are the numbers already present?
  2. Are the numbers all formatted per your first example?
    1. Numbers are not zero-padded
    2. Always a space before the number
  3. How high do the numbers go?
  4. How many roadway types do you have in this dataset (e.g., ST, DR, RD, STREET)
    1. Be exacting here: "ST" and "STREET" would likely need to be treated differently.
BETAGIS
New Contributor II
Hi, thank you for the response. I have an answer for each of your questions:
1.) Yes the numbers are already present
2.) Yes, all numbers are per my first example throughout the dataset - always a space before the number.
3.) The highest number is 115 on one of the larger length roads in the dataset.
4.) There are 10 roadway types in total - they are all abbreviated: ST, PL, DR, RD, PKWY, PK, AVE, WAY, TER, and CT
If you think it's better to do it "manually" - I'll trust your judgement. Thanks again!
JoshuaBixby
MVP Esteemed Contributor
If the max number goes to 115, do you want the result to be "001" so that all the values are 3 characters.
BETAGIS
New Contributor II
No, I'd prefer the numbers to be "01" and then be 3 characters if necessary.
AllenDailey1
Hello,
    if len(num) == 1:
        num = "-0" + num
    else:
        num = "-" + num
    return result
for st in sts:
MY ST-01
MY ST-02
MY ST-10
MY ST-41
BETAGIS
New Contributor II
Thanks a bunch! That did exactly what I was trying to do. Will keep this in the back pocket for future uses.
AllenDailey1
Awesome, I'm glad!
