How can I delete a field with a different name in a list of feature classes?
4325
01-17-2015 02:07 PM
GabrielBacca-Cortes
New Contributor II
Hi All -
I am trying to delete a field in list of feature classes that changes name depending upon FC is in. This field in all FC has two things in common:
i) the field name starts with "FID_" in all the FCs,
ii) the field is located third [3rd] in the list of fields, right after the fields "FID" and "Shape".
With this in mind, I've tried a couple of things, as shown below, but they don't seem to work. I appreciate any ideas/suggestions you may have.
thanks !
Gabriel
import arcpy, os
from arcpy import env
env.workspace = r"C:\GIS\Track1\1_Orig\Track_int1"
wildcard = "xy**.shp"
fctype = "POLYLINE"
try:
    fclist =  arcpy.ListFeatureClasses(wildcard, fctype)
    for fc in fclist:
# I'VE TRIED THIS:
##        desc = arcpy.Describe(fc)
##        # Get a list of field objects from the describe object
##        fields = desc.fields
##        for field in fields:
##            if field.name == "FID_**":
##                arcpy.DeleteField_management(fc, "FID_**")
##                break
# AND THIS:
            fieldList =  arcpy.ListFields(fc)
            fieldToDel =  fieldList[3:]
           arcpy.DeleteField_management(fc, fieldToDel)
except:
    print arcpy.GetMessages(0)
    print arcpy.GetMessages(1)
    print arcpy.GetMessages(2)
JoshuaCrough
New Contributor III
This should work:
import arcpy, os
fctype = "POLYLINE"
try:
    for fc in fclist:
        for field in fieldList:
            if field.name[:4] == "FID_":
                deleteField = field.name
                arcpy.DeleteField_management(fc, deleteField)
except:
DanPatterson_Retired
the 3rd field is index number 2 ie fieldList[2]  please try this and any other attempts on backups!!!!
GabrielBacca-Cortes
New Contributor II
Dan -  thanks for your response.
I've tried that but I am still getting the same errors:
ERROR 000622: Failed to execute (DeleteField). Parameters are not valid.
ERROR 000623: Invalid value type for parameter drop_field.
any other ideas ?
thanks
Gabriel
JoshuaCrough
New Contributor III
This should work:
import arcpy, os
fctype = "POLYLINE"
try:
    for fc in fclist:
except:
GabrielBacca-Cortes
New Contributor II
Thank you Joshua !  that did the trick...   i am really new to this and during my first readings I had seen that format [:4], but had completely forgotten.  thanks again !
Gabriel
