This is just for my benefit... I'm trying to teach myself python. I have programming experience with other languages, but not python and not arcpy (or arcgisscripting for that matter)import arcpy
#Initialize variables
searchDSParam = None
searchLinkParam = None
searchFieldParam = None
updateDSParam = None
updateLinkParam = None
updateFieldParam = None
#arcGIS toolbox script
#searchDSParam = arcpy.GetParameterAsText(0)
#searchLinkParam = arcpy.GetParameterAsText(1)
#searchFieldParam = arcpy.GetParameterAsText(2)
#updateDSParam = arcpy.GetParameterAsText(3)
#updateLinkParam = arcpy.GetParameterAsText(4)
#updateFieldParam = arcpy.GetParameterAsText(5)
#for testing
searchDSParam = "C:\GIS\VirtualCampus\SpatialStatsModelBuilder\ModelBuilderTutorial\CDCWonderAnalysis.gdb\HeartDiseaseSouth_1999"
searchLinkParam = "CountyCode"
searchFieldParam = "HD_Rate"
updateDSParam = "C:\GIS\VirtualCampus\SpatialStatsModelBuilder\ModelBuilderTutorial\CDCWonderAnalysis.gdb\HD_Rate_1999"
updateLinkParam = "FIPS"
updateFieldParam = "HDrate"
updateTheRow = None
updateTheRows = None
searchTheRow = None
searchTheRows = None
updateTheFields = None
searchTheField = None
searchTheFields = None
fldType = None
fldPrecision = None
fldScale = None
fldLength = None
whereClause = None
linkTypeText = False
#Dictionary to convert return value from field.type to set value using AddField
fieldTypeDictionary = {'SmallInteger': 'SHORT', 'Integer': 'LONG', 'Single': 'FLOAT', 'Double': 'DOUBLE', 'String': 'TEXT', 'Date': 'DATE'}
changed = 0
try:
#get work done
#add field to update dataset if necessary
#search cursor has data to be applied to update cursor (in searchFieldParam field)
#update cursor has field to be updated (updateFieldParam gets data from searchFieldParam)
#link update cursor with search cursor on fields searchLinkParam/updateLinkParam
updateTheFields = arcpy.ListFields(updateDSParam) #get a list of fields in shapefile to be updated
searchTheFields = arcpy.ListFields(searchDSParam) #get a list of fields in the shapefile to be searched
for searchTheField in searchTheFields:
if searchTheField.name == searchFieldParam:
fldType = searchTheField.type
fldPrecision = searchTheField.precision
fldScale = searchTheField.scale
fldLength = searchTheField.length
if searchTheField.name == searchLinkParam:
if searchTheField.type == "String":
linkTypeText = True
#check to see if it has the field that will be updated, if it has it good; if not then add the field
#NOT SURE THIS IS WORKING FOR THE CASE WHEN FIELD ALREADY EXISTS - HAVE NOT TESTED YET - BUT IT ADDS FIELD OK (Have been deleting the field for testing)
if not updateFieldParam in updateTheFields:
#field does not exist - need to add field
arcpy.AddField_management(updateDSParam,updateFieldParam,fieldTypeDictionary[fldType], fldPrecision, fldScale, fldLength) #adds field to data set
updateTheRows = arcpy.UpdateCursor(updateDSParam) #get the rows from the shapefile that will have a field updated
for updateTheRow in updateTheRows:
#loop through all the rows in the update cursor
if linkTypeText:
whereClause = "'" + searchLinkParam + "' = '" + updateTheRow.getValue(updateLinkParam) + "'"
else:
whereClause = "'" + searchLinkParam + "' = " + updateTheRow.getValue(updateLinkParam)
if updateTheRow.getValue(updateLinkParam) == "01001":
print updateTheRow.getValue(updateLinkParam)
# THIS SECTION NOT WORKING...SEARCH CURSOR DOESN'T LOAD DATA (EVEN WITHOUT WHERECLAUSE)
searchTheRows = arcpy.SearchCursor(searchDSParam,whereClause)
for searchTheRow in searchTheRows:
if searchTheRow.getValue(searchFieldParam) <> "":
updateTheRow.setValue(updateFieldParam,searchTheRow.getValue(searchFieldParam))
updateTheRows.updateRow(updateTheRow)
changed = changed + 1
break #exit search cursor loop - you found first row with data and updated row
except:
# Display exceptions
if not arcpy.GetMessages() == "":
arcpy.AddMessage(arcpy.GetMessage(2))
finally:
#clean up everything
if updateTheFields:
del updateTheFields
if searchTheFields:
del searchTheFields
if searchTheField:
del searchTheField
if searchTheRow:
del searchTheRow
if updateTheRow:
del updateTheRow
if updateTheRows:
del updateTheRows
if searchTheRows:
del searchTheRows
if searchDSParam:
del searchDSParam
if searchLinkParam:
del searchLinkParam
if updateDSParam:
del updateDSParam
if searchFieldParam:
del searchFieldParam
if updateLinkParam:
del updateLinkParam
if updateFieldParam:
del updateFieldParam
if fldLength:
del fldLength
if fldType:
del fldType
if fldPrecision:
del fldPrecision
if fldScale:
del fldScale
if whereClause:
del whereClause
if linkTypeText:
del linkTypeText
if fieldTypeDictionary:
del fieldTypeDictionary
