I need to create a search cursor to print out the values in an attribute table for a school shapefile. I need to print out all the values that correspond to HIGH SCHOOL in the field FACILITY for the School shapefile. For some reason the search cursor won't work when I try to apply the sql expression but works without it. I don't want to print out all the values in that field just specific ones. Is there something wrong with my sql statement?
#import arcpy module
import arcpy
from arcpy import env
arcpy.env.overwriteOutput = True
# I am setting the work path
env = 'S:\\376\\Summer15-2\\ahutche1\\lab07_data\\SectionB\\'
#I will set the variable for the schools shapefile
schools = 'Schools'
#create search cursor to loop thru schools. use where clause to return schools
#that are high schools. Use loops
#print out all the highschool names
#print total no. of high school records
sr = arcpy.SpatialReference(4326)
#I will create a search cursor for the schools shapefile
field = "FACILITY"
exp1 = '"FACILITY" = "HIGH SCHOOL"'
cursor = arcpy.SearchCursor(env+schools+'.shp',exp1)
for row in cursor:
print(row.getValue(field))
