I found a script that allows the input of a feature class and then it deletes all the fields in a feature class with the exception of those listed in the "if" statement. The script works great when passing 1 feature class or 1 file geodatabase table. However, I need to pass a list of tables as the input, and when I do, I get the error: IOError: "[ list of all the tables I tried to enter]" does not exist. Below is the script with my attempted modifications. Is what I am trying to do possible? Thank you in advance.
John
import arcpy
from arcpy import env
env.workspace = r"C:\user\test22\test_tables.gdb"
list_filename_Tables = arcpy.ListTables("*_filename*")
fc = list_filename_Tables
for f in arcpy.ListFields(fc):
if (f.name == 'OBJECTID' or f.name == 'ID' or f.name == 'Project1' or f.name == 'Height'):
print("cant delete {}".format(f.name))
else:
arcpy.DeleteField_management(fc, f.name)
