I have a simple script that is doing some parsing of the mxd that I pass it. The script works just fine if I hard code the name of the mxd into the script, however I would like to pass the full path of the mxd to the script when I run it. This seems to be an issue since the examples I have seen all have the ???r??? in them prior to the path and mxd name. For example(this works by the way): mxd = arcpy.mapping.MapDocument(r"C:\Data\GISData\PythonCode\test.mxd")
I???ve tried a number of things but haven???t figured out how to get around this simple problem. For Example:mxdIn = sys.argv[0] mxd = arcpy.mapping.MapDocument(mxdIn)
Also tried:mxdIn = sys.argv[0] mxd = arcpy.mapping.MapDocument(r (mxdIn))
Thanks for your help in advance!
