Hi all, all. To upload a file in an FTLS I used the FTP_TLS from ftplib, here is my code (I adapted from a code found on the web):
import ftplib from ftplib
import FTP_TLS
import os
import ssl
import sys
server = XXXXXXXXXXXXX
user = XXXXXXXXXXXXXXXX
passwd = XXXXX
PathFile = 'Q:\GW\EC1140WH_Con_HF\HCM_CARTS'
def connect_ftp():
ftp = FTP_TLS(server, user, passwd)
ftp.set_pasv(True)
ftp.prot_p()
ftp.set_debuglevel(2)
return ftp
def upload_file(ftp_connection, upload_file_path):
try:
upload_file1 = open(os.path.join(PathFile,upload_file_path), 'r')
print('Uploading ' + upload_file_path + "...")
ftp_connection.storbinary('STOR ' + upload_file_path, upload_file1)
ftp_connection.quit()
ftp_connection.close()
upload_file.close()
print('Upload finished.')
except Exception, e:
print("Error uploading file: " + str(e))
ftp_conn = connect_ftp()
if ftp_conn:
print("Success connection")
upload_file(ftp_conn, 'LisezmoiReadme.docx')
Unfortunatly, I got the message:
Success connection
Uploading LisezmoiReadme.docx...
*cmd* 'TYPE I' *put* 'TYPE I\r\n'
*get* '200 Type set to I.\r\n'
*resp* '200 Type set to I.'
*cmd* 'PASV' *put* 'PASV\r\n'
*get* '227 Entering Passive Mode (142,34,138,110,197,108).\r\n'
*resp* '227 Entering Passive Mode (142,34,138,110,197,108).'
*cmd* 'STOR LisezmoiReadme.docx'
*put* 'STOR LisezmoiReadme.docx\r\n'
*get* '125 Data connection already open; Transfer starting.\r\n'
*resp* '125 Data connection already open; Transfer starting.'
*get* '425 Data channel timed out due to not meeting the minimum bandwidth requirement.\r\n'
*resp* '425 Data channel timed out due to not meeting the minimum bandwidth requirement.'
Error uploading file: 425 Data channel timed out due to not meeting the minimum bandwidth requirement.
The last line is the error and i dont know how to resolve it? Any help please? Is it better to use the transfercmd command?
I use ArcGIS 10.1
Thanks a lot
