sorry tried that i couldnt find where the advanced editor is. will this be helpfull?
#Import system modules
import arcpy
import os
import xlrd
#Check license for extensions
print "checking license for extensions"
arcpy.CheckOutExtension("Analysis")
#Setting workspace
print "setting up workspace"
arcpy.env.workspace = os.getcwd()
#Overwrite outputs
print "Outputs will be overwritten"
#Input data
print "checking input data layers"
primary = "\\nz-primary-parcels\\nz-primary-parcels.gdb\\NZ_Primary_Parcels"
TitleOwners = "\\nz-property-titles-including-owners\\nz-property-titles-including-owners.gdb\\NZ_Property_Titles_Including_Owners"
Out_path = "C:\\Users\\jkrishna\\Documents\\TPG Mapping\\NZTA\\Wellington\\NZ5yearRollingPlan\\Data\\Wellington-Geodatabase.gdb"
Table = "\\Wellington.xls"
#out_join = "\\Wellington-Geodatabase.gdb\\TitleOwnerJoin"
#Adding a parcel ID Field and Project Field to primary parcels
print " Adding ParcelID field and Project field"
arcpy.AddField_management (primary, "ParcelID", "LONG", "", "", 15)
arcpy.AddField_management (primary, "Project", "TEXT", "", "", 30)
arcpy.AddField_management (primary, "SAP_Ref", "LONG", "", "", 15)
#Copying data from ID field to ParcelID
print "Copying data from id field to ParcelID"
arcpy.CalculateField_management (primary, "ParcelID", '[id]')
#Create a layer file to work with
print "Creating a primary layer file"
layerfile = "primary.lyr"
arcpy.MakeFeatureLayer_management(primary, layerfile)
#Spatial join primary parcel and titleowners
print "Spatial joining primary parcel and titleowners"
out_join = Out_path + "\\TitleOwnerJoin"
arcpy.SpatialJoin_analysis (layerfile, TitleOwners, out_join, "JOIN_ONE_TO_MANY", "KEEP_ALL", "", "WITHIN")
spreadsheet = [Table + "\\BasinReserve$", Table + "\\DowseToPetone$"]#, Table + "\\InnercityBypass$", Table + "\\M2pp$",
#Table + "\\ManaParemata$", Table + "\\MellingIc$", Table + "\\MungavinIc$", Table + "\\MuriroadPukeruabay$",
#Table + "\\MtVicTunnel$", Table + "\\NgaurangaGorge$",Table + "\\NO2LTaylorsRdtoLevin$", Table + "\\NO2LWaitarereCurves$",
#Table + "\\PP2O$", Table + "\\PaekakarikiIC$",Table + "\\ParemataCarParking$", Table + "\\PukeruaBay$",
#Table + "\\SH2BPHuttRd$", Table + "\\SH58$", Table + "\\TransmissionGully$", Table + "\\WaitangiruaCorridor$",
#Table + "\\WUMAuroraTerrace$", Table + "\\WUMMurphyToMolesworthSt$", Table + "\\WUMTinakoriRd$"]
for project in spreadsheet:
print spreadsheet
#Convert excel sheet to Dbase table
print " Converting excel sheet to Dbase table"
out_dbase = "C:\\Users\\jkrishna\\Documents\\TPG Mapping\\NZTA\\Wellington\\NZ5yearRollingPlan\\Data"
out_name = project + ".dbf"
arcpy.TableToTable_conversion (project, out_dbase, out_name)
print "Creating a parceljoin layer file"
joinlayer = "parceljoin.lyr"
arcpy.MakeFeatureLayer_management(out_join, joinlayer)
#Join title owners featureclass,Project dbf and Copy data from project dbf to title owners featureclass
print" Join table using parcelid field"
arcpy.AddJoin_management (joinlayer, "ParcelID", out_name, "ParcelID", "KEEP_COMMON")
print "Starting edit session"
arcpy.da.Editor(Out_path)
print "copying SAP no"
arcpy.CalculateField_management (joinlayer, "TitleOwnerJoin.SAP_Ref", '['+project+'.SAP_Refere]')
print "Copying project info to project field"
arcpy.CalculateField_management (joinlayer, "Project", '"'+project+'"')
print "Remove join"
arcpy.RemoveJoin_management (joinlayer, name)
print "done"
