We have a python script wired to a toolbox that suddently started throwing the below error at 3.2.1. Pro 3.1.3 doesn't have any issues opening this tool in Pro, but 3.2.1 will not even open the tool for users to input parameters.
Anyone experience this, how to diagnose?
initializeParameters Error: UnicodeDecodeError: 'utf-8' codec can't decode byte 0x91 in position 8: invalid start byteThe above exception was the direct cause of the following exception:Traceback (most recent call last):File "C:\Users\david\QAP_Toolbox.tbx#CIPAutoQAPRound2.InitializeParameters.py", line 29, in <module>File "C:\Users\david\QAP_Toolbox.tbx#CIPAutoQAPRound2.InitializeParameters.py", line 8, in __init__File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py", line 1603, in GetParameterInforeturn ParameterArray(gp.getParameterInfo(tool_name))File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 457, in getParameterInfoself._gp.GetParameterInfo(*gp_fixargs(args, True)))SystemError: <built-in method getparameterinfo of geoprocessing object object at 0x000001D11824C150> returned a result with an error set
Hey,
I have observed the same problem. I use the Validation Tool Class very intensively. Everything runs smoothly in ArcGIS Pro 3.1. As of 3.2 I get the same error as you. The error only disappears if I reset the Validation Tool Class to the default, i.e. I don't have my own code in it. Of course it doesn't make sense since I already need my code in there. I don't use a special character either.
I am also interested in a solution :).
Best
Sven
Hey,
We had the same problem with some of our custom python scripts in ArcGIS Pro 3.2.1. Looks like the parameters name (not the label) must not contain any special characters (we're german, so we used ä,ö,ü,ß before). Worked for us.
Best
Holger
Great tip, I found that in one of the tool's input parameters (a boolean in this case, not that it matters) Name had apostrophes and a dash like this: '-999' and once I retyped the '-' around the 999 it fixed the issue!
