We have a python script wired to a toolbox that suddently started throwing the below error at 3.2.1. Pro 3.1.3 doesn't have any issues opening this tool in Pro, but 3.2.1 will not even open the tool for users to input parameters.
Anyone experience this, how to diagnose?
initializeParameters Error: UnicodeDecodeError: 'utf-8' codec can't decode byte 0x91 in position 8: invalid start byte
The above exception was the direct cause of the following exception:
File "C:\Users\david\QAP_Toolbox.tbx#CIPAutoQAPRound2.InitializeParameters.py", line 29, in <module>
File "C:\Users\david\QAP_Toolbox.tbx#CIPAutoQAPRound2.InitializeParameters.py", line 8, in __init__
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py", line 1603, in GetParameterInfo
return ParameterArray(gp.getParameterInfo(tool_name))
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 457, in getParameterInfo
self._gp.GetParameterInfo(*gp_fixargs(args, True)))
SystemError: <built-in method getparameterinfo of geoprocessing object object at 0x000001D11824C150> returned a result with an error set
