a shapefile would be in a folder and the *.shp file extension would be expected
your path contains spaces which isn't good and leading numbers for folders aren't great either.
Is the W drive local? a zip drive etc.
The file path, when you create a new one, should be raw encoded, (the little preceeding 'r') so try putting the shapefile into a simple folder path like
r"c:\data\my_shapefile.shp"
... sort of retired...
