Join field in feature class to field MS Access table 2007 format
669
08-16-2013 12:49 AM
PriyankaMehta
I am trying to join fields from a feature class in geodatabase to a field in MS Access database.
This statement used to work fine for 2003 format of ms access but for 2007 format it gives an error
gp.JoinField_management(gdbfeat1,"gdbField1",accdbtable1,"accField1","accField2")
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Join Table: Dataset tablexxx does not exist or is not supported
although it clearly exists and it is being able to do execute other statements like
cursor.execute("delete * from " + accdbtable1)  which is inside the same loop.
Can somebody please point how should I join fields from geodatbase table to ms access table.
Thanks in advance,
Priyanka
JamesCrandall
MVP Frequent Contributor
Post the complete code.  What is the error(s)?  How are you connecting to the MS Access db?  Perhaps you need to provide fully qualified table/field names for the join?
Jut not enough info to give you a direct answer.
james
PriyankaMehta
I am using Pyodbc to connect to access database
import pyodbc, arcgisscripting,arcpy
arcpy = arcgisscripting.create(10.1)
arcpy.overwriteoutput = 1
conn = pyodbc.connect(("Driver={Microsoft Access Driver (*.mdb, *.accdb)};"
                                     "DBQ=C:\Projects\ProjectDatabases\MIA\PrimaryDatabase.accdb;"))
cursor = conn.cursor()
InputTransport = "C:\ProjectDatabases\GIS\SIWW_Data_Display.gdb"
def TransportationAccess(accdbtable1,gdbfeat1):
                cursor.execute("delete * from " + accdbtable1)  #clear table
                #join Trans_NodeTypeDetails from geodatabase to Acces_Trans_NodeTypeDetails. Join fields NodeType and Stations
                arcpy.joinfield_management((InputTransport+"\\"+gdbfeat1),"NodeType",accdbtable1,"NodeType","Stations")
TransportationAccess("Access_Trans_NodeTypeDetails", "Nodes")
Feature class in geodatabase (gdbfeat1 in code) is "Nodes"
Table in MS Access(accdbtable1) is "Access_Trans_NodeTypeDetails"
I am trying to join these two tables.
and I get this error saying "Access_Trans_NodeTypeDetails" does not exist. It is the same same table that it is clearing in the previous line.
this is the error that I get
ERROR 000732: Join Table: Dataset Access_Trans_NodeTypeDetails does not exist or is not supported
Failed to execute (JoinField).
Priyanka
JamesCrandall
First, where are you setting "accdbtable1" or "Access_Trans_NodeTypeDetails" before invoking the TransportationAccess() method???
Second, I am unsure if the Access_Trans_NodeTypeDetails meets the requirement of the join operation.  From the help http://resources.arcgis.com/en/help/main/10.1/index.html#//001700000064000000
[INDENT]The Join Table can be any of the following types of tables: a geodatabase table (ArcSDE, file, or personal), a dBASE file, an INFO table, or an OLE DB table.[/INDENT]
...which I don't think your .accdb table meets any of these.  One thing I would try is apply this to a TableView first, then join that to the FeatureLayer
                tblv = "accdbtab"
                arcpy.MakeTableView_management(accdbtable1, tblv)
                arcpy.joinfield_management((InputTransport+"\\"+gdbfeat1),"NodeType",tblv,"NodeType","Stations")
But why exactly are you attempting to "clear" accdbtable1 before the join operation???  That makes no sense to join an empty table.
Also, that is untested above and I am not even sure if this is the problem but maybe worth a try.
AmyKlug
Occasional Contributor III
you can use this tool  http://resources.arcgis.com/en/help/main/10.1/index.html#//001200000027000000 or convert your .accdb to a .mdb and access through a database connection
PriyankaMehta
Thanks for the suggestions but nothing worked. accdb format MS Access table could not be brought to the geodatabase or layer view directly.
i dont know if it was the best method but I finally ended up creating a new empty table in geodatabase and inserting the values from access table to geodatabase and using that for joining.
I used the insert cursor procedure and made a replica of my Access table in geodatabase.
Thanks for the suggestions !
Priyanka
