Solved! Go to Solution.
def FindLabel ( [Field1], [Field2] ): if float([Field1]) >= 1: return "# " + str([Field1]) + ", " + "<CLR red='255'><FNT size = '16'>" + "Field 2 " + str(round(float( [Field2]) , 2)) + "</FNT></CLR>" else: return "# " + str([Field1]) + ", Field 2 " + str(round(float([Field2]) ,2))
FindLabel([Field1],[Field2])
def FindLabel (f1,f2): if f1 >= 1: lbl = "# {0}, <CLR red='255'><FNT size='16'> Field 2: {1:.2f}</FNT></CLR>" else: lbl = "# {0}, Field 2: {1:.2f}" return lbl.format(f1,f2)
