Labels in .lyr file
2114
13
02-20-2013 09:34 AM
GlenReid
New Contributor II
I'm converting an older GP task made using MB to Python.
In the original, data was saved to disk (.shp) and rendered with a layer file (.lyr).  Labels were displayed in the output.  I've updated the .lyr file to work with an in_memory layer (longer field names).  Here is the code:
import arcpy  arcpy.env.workspace = r"C:\gis-ags\src\gp"  # temporary date_range = "\"OBDATE\" BETWEEN date '2008-01-01' AND date '2008-01-03'"  # Script arguments #date_range = arcpy.GetParameterAsText(0) if date_range == '#' or not date_range:     date_range = "\"OBDATE\" BETWEEN date '2008-01-01' AND date '2008-01-03'"  # Local variables accum_table = "in_memory\\accumulation_table" stat_table = "in_memory\\stat_table" db_table = r"C:\gis-ags\src\gp\gisselect_cdo.sde\GIS.DAILYSNOW_GP_DATA"  # Table Select arcpy.TableSelect_analysis(db_table, accum_table, date_range)  # Summary Statistics arcpy.Statistics_analysis(accum_table, stat_table, "NAME FIRST;STATE FIRST;SNOWFALL SUM;LATITUDE FIRST;LONGITUDE FIRST", "COBAN")  # Spatial Reference sr = arcpy.SpatialReference() sr.factoryCode = 4269 sr.create()  # Make XY Event Layer lyr = "accum_xy_layer" arcpy.MakeXYEventLayer_management(stat_table, "FIRST_LONGITUDE", "FIRST_LATITUDE", lyr, sr)  # Symbology symbology_layer = "accumulation.lyr" arcpy.ApplySymbologyFromLayer_management(lyr, symbology_layer)
For some reason, the labels are not getting displayed when I run in the ArcMap Python Window.
Am I missing something?
Glen
T__WayneWhitley
I can no longer be certain what line 50 refers to - post your entire code again.  (you should no longer have a line 50)
Is your lyr file where you have set your workspace?
I am posting the full code I think you should have by now:
import arcpy  arcpy.env.workspace = r"C:\gis-ags\src\gp"  # temporary date_range = "\"OBDATE\" BETWEEN date '2008-01-01' AND date '2008-01-03'"  # Script arguments #date_range = arcpy.GetParameterAsText(0) if date_range == '#' or not date_range:     date_range = "\"OBDATE\" BETWEEN date '2008-01-01' AND date '2008-01-03'"  # Local variables accum_table = "in_memory\\accumulation_table" stat_table = "in_memory\\stat_table" db_table = r"C:\gis-ags\src\gp\gisselect_cdo.sde\GIS.DAILYSNOW_GP_DATA"  # Table Select arcpy.TableSelect_analysis(db_table, accum_table, date_range)  # Summary Statistics arcpy.Statistics_analysis(accum_table, stat_table, "NAME FIRST;STATE FIRST;SNOWFALL SUM;LATITUDE FIRST;LONGITUDE FIRST", "COBAN")  # Spatial Reference sr = arcpy.SpatialReference() sr.factoryCode = 4269 sr.create()  # Make XY Event Layer lyr = "accum_xy_layer" arcpy.MakeXYEventLayer_management(stat_table, "FIRST_LONGITUDE", "FIRST_LATITUDE", lyr, sr)  # Symbology symbology_layer = "accumulation.lyr"  mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd, "")[0]  lyr = arcpy.mapping.ListLayers(mxd, 'accum_xy_layer', df)[0] arcpy.ApplySymbologyFromLayer_management(lyr, symbology_layer) lyr.showLabels = True  arcpy.RefreshActiveView()
EDIT:  It could be you cannot use ApplySymbologyFromLayer to update labeling - this may be more about what you want, using labelClasses, as posted here by Craig McDade:
http://forums.arcgis.com/threads/78032-Attempting-to-use-showLabels-script-within-a-model...#3
-Wayne
by Anonymous User
Not applicable
I think you should just need to add this after you apply the symbology:
GlenReid
New Contributor II
Caleb,
Thanks for the reply.  I had already tried that with this result
Runtime error
  File "<string>", line 47, in <module>
AttributeError: 'str' object has no attribute 'showLabels'
I could try to create a feature class, but thought that shouldn't be necessary.
Glen
by Anonymous User
Not applicable
Caleb,
Runtime error
Glen
Ahh, I see the problem here.  You will need to create a layer object before you can change the layer's properties.  Maybe try something like this:
for lyr in arcpy.mapping.ListLayers('accum_xy_layer')[0]:
T__WayneWhitley
lyr you have set to text, so that's why you get the error.
You used the lyr string to write your event layer - so you need a handle on the event layer object...
Caleb?  Ahhh, I see you posted again - yes, that should do it!  ...he's going to need the code snippet to get at the CURRENT mxd object (and dataframe likely) as well.  After re-reading his post, looks like Glen may want to 'overwrite' his layer file with the label settings from the temp layer in the map.  Better confirm that.
Enjoy,
Wayne
GlenReid
New Contributor II
Thanks for the replies.
I have added the ListLayers code, so it now looks like:
import arcpy
# temporary
# Script arguments
# Local variables
# Table Select
# Spatial Reference
sr.create()
# Symbology
I still get a runtime error.
Runtime error
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\utils.py", line 181, in fn_
    return fn(*args, **kw)
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\mapping.py", line 1500, in ListLayers
    result = mixins.MapDocumentMixin(map_document_or_layer).listLayers(wildcard, data_frame)
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\arcobjects\mixins.py", line 823, in listLayers
    layers = self.layers
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\arcobjects\mixins.py", line 683, in layers
    for frame in reversed(self.dataFrames):
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\arcobjects\mixins.py", line 695, in dataFrames
    return map(convertArcObjectToPythonObject, self.pageLayout.dataFrames)
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\arcobjects\mixins.py", line 679, in pageLayout
    return convertArcObjectToPythonObject(self._mxd._arc_object.pageLayout)
AttributeError: 'str' object has no attribute '_arc_object'
I thought that since I previously specified labeling and saved to a .lyr file, that this would be taken care of in the ApplySymbologyFromLayer.
Glen
by Anonymous User
Not applicable
Sorry, I did not look at the full code.  My example was for if you were accessing an mxd.  So are you just wanting to save this "accum_xy_layer" as a layer file?  It would be nice if the apply symbology worked for labels too.  I haven't been able to find anything that shows how to copy the label properties from another layer file.  There is a way to read label classes but I believe that is only for layers inside an mxd.  Hopefully someone else knows how to do this?
T__WayneWhitley
Yeah, forget please what I said earlier about writing back to lyr file...
Evidently the same problem or 'disconnect' exists, meaning you do not have a handle to the layer...
The layer is in the map, I mean your event layer has been added?
If so try adding this (and I included Caleb's part of it) - I think that will correctly make the association through your currently operating mxd, correct me if I'm wrong please Caleb (I'm not sure):
# Symbology
for lyr in arcpy.mapping.ListLayers(mxd, 'accum_xy_layer', df)[0]:
You may have to refresh the map yourself...
Sorry, forgot that.
Enjoy,
Wayne
GlenReid
New Contributor II
The event layer does get added to the mxd, but only because my GP options are set so.
I added the code and get this error:
Runtime error
  File "<string>", line 50, in <module>
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\arcobjects\mixins.py", line 361, in __iter__
    self.layers
AttributeError: LayerObject: Get attribute layers does not exist
T__WayneWhitley
-Wayne
