Loop through multiple folder and Calculate mean of raster of Same folder
3812
23
03-24-2017 12:18 PM
ShouvikJha
Occasional Contributor III
Hi All,
I am writing a script to loop through multiple folders and calculate mean of the raster of each folder's data sets and save it in same folder. Below script i am working, but its not producing the mean rasters for each year folder, after running the script its generating only name of "mean" raster in main folder, and overlapping it .
Below images showing the name of the raster in one folder, another folder the raster name is same, only year value is changed in different year.
here how to take the year value in name of mean raster (E.g. for 2001 folder, output mean raster name would be Mean_Temp_2001.tif, E.g. for 2002 folder, output mean raster name would be Mean_Temp_2002.tif)
Below i have attached data sets also (Test_data folder)v which i am working on.
Thanks.
import arcpy, os
from arcpy import env
arcpy.CheckOutExtension("Spatial")
arcpy.env.overwriteOutput = True
env.workspace = r"D:\Test"
outraster = env.workspace
walk = arcpy.da.Walk(env.workspace, topdown=True, datatype="RasterDataset")
for dirpath, dirnames, filenames in walk:
    print dirpath
    rasterList = []
    for file in filenames:
        raster = os.path.join(dirpath, file)
        rasterList.append(raster)
        rasMean = arcpy.sa.CellStatistics(rasterList,"MEAN")
        rasMean.save(os.path.join(outraster,"mean.tif"))
        print rasMean‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
ShouvikJha
xander_bakker‌, please cooperate with us to solve the issue.
DanPatterson_Retired
perhaps you could show the edited code instead of snippets which are then out of context and incorrect as they stand
ShouvikJha
please tell me which way to solve the issue.
RustyRex
I think you missed Dan's comment. rasmean is a raster object, although I would expect something to be printed. Did you check the workspace directory to see if any .tif have been saved there?  Also i would print your rasterList to help debug.  I suspect one of your problems is there.  CellStatistics is looking for a list of rasters and your are looping through the list of rasters and giving it one item from the list which implies that rasterList is a list of list.
ShouvikJha
192 views , still received input from 3 -4 developer only.
XanderBakker
Esri Esteemed Contributor
Hi shouvik jha , It is always a good thing to add data to the thread (if possible) since sometimes the issue is data related. I haven't looked at the specific situation of you case yet, but I notice that you are using names for your rasters that start with a number. It is beter to avoid that.
I have been traveling a lot lately, but if the thread is not solved by tomorow evening I will see if I can do something if you attach the data to the thread.
Kind regards, Xander
ShouvikJha
Xander Bakker‌, Thanks for your respond. I have attached the datasets to thread.
XanderBakker
Hi shouvik jha , try the script below (change the input path at line 7):
def main():
    import arcpy
    import os
    ws = r'C:\GeoNet\LMFCMSF\Test_Data'
    walk = arcpy.da.Walk(ws, topdown=True, datatype="RasterDataset")
        print "Processing folder:", dirpath
        rasters = []
        for filename in filenames:
            raster = os.path.join(dirpath, filename)
            if filename.upper().endswith('.TIF'):
                if filename.upper().startswith('MEAN') == False:
                    rasters.append(raster)
        print " - rasters found:", len(rasters)
        if len(rasters) != 0:
            print " - calculate mean..."
            file_name_only = os.path.splitext(rasters[0])[0]
            tifname = file_name_only[-4:]
            ras_mean = arcpy.sa.CellStatistics(rasters, "MEAN", "DATA")
            ras_mean_name = os.path.join(dirpath,'Mean_{0}.tif'.format(tifname))
            ras_mean.save(ras_mean_name)
            print " - save mean raster as:", ras_mean_name
        else:
            print " - skipping folder..."
    print "Finished..."
if __name__ == '__main__':
    main()
This will print the following text:
Processing folder: C:\GeoNet\LMFCMSF\Test_Data
 - rasters found: 0
Processing folder: C:\GeoNet\LMFCMSF\Test_Data\2001A
 - rasters found: 12
 - calculate mean...
 - save mean raster as: C:\GeoNet\LMFCMSF\Test_Data\2001A\Mean_2001.tif
Processing folder: C:\GeoNet\LMFCMSF\Test_Data\2002A
 - rasters found: 12
 - calculate mean...
 - save mean raster as: C:\GeoNet\LMFCMSF\Test_Data\2002A\Mean_2002.tif
Processing folder: C:\GeoNet\LMFCMSF\Test_Data\2003A
 - rasters found: 12
 - calculate mean...
 - save mean raster as: C:\GeoNet\LMFCMSF\Test_Data\2003A\Mean_2003.tif
Processing folder: C:\GeoNet\LMFCMSF\Test_Data\2004A
 - rasters found: 12
 - calculate mean...
 - save mean raster as: C:\GeoNet\LMFCMSF\Test_Data\2004A\Mean_2004.tif
Finished...
The resulting rasters seem to be OK...
ShouvikJha
xander_bakker‌, Thank you very much. Now its working fine.
XanderBakker
I'm glad it works. If you need additional explanation of the steps, please let me know.
