I just had great success with the following edits to this code. Thanks for sharing it. I also was able to change it to export JPEGs.I'm attaching my Python script.#DDP: Set Definition Query on a secondary index
#Variables that need to be set by user:
#mxdpath = r'C:\Users\Test.mxd' # string
#outputfolder = 'PDFFolder' # string
#namefield = 'THE FIELD CONTAINING THE NAME OF THE RESULTING PDF FILE' #string
#queryfield = 'THE FIELD CONTAINING THE VALUE FOR THE DESIRED QUERY' #string
#layers = ['LIST','OF','LAYERS'] # list ('Layer1_UpdateQuery', 'Layer2_UpdateQuery', 'etc')
#Import Modules
import arcpy, os
# Set Variables
mxdpath = r'D:\arcgis\Samples\DDP_Index2.mxd' # string
outputfolder = 'D:\PDF' # string
namefield = 'FIPS' # string
queryfield = 'STATE_NAME' # string
layers = ['CountySel_FIPS'] # list
mxd = arcpy.mapping.MapDocument(mxdpath)
# Start Loop through Data Driven Pages
for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1):
mxd.dataDrivenPages.currentPageID = pageNum # set the current page
pageName = mxd.dataDrivenPages.pageRow.getValue(namefield) # get the pageName
pageName += '.pdf' # add '.pdf' extension for file name
pdf = os.path.join(outputfolder, pageName) # add pageName to output folder to get full output path
# Start Loop through all layers of mxd file
for lyr in arcpy.mapping.ListLayers(mxd): # for every layer in mxd's Layer List
if lyr.name in layers: # if layer name in user input list above
#value = mxd.DataDrivenPages.pageRow.getValue(queryfield) # get value of query field
value = mxd.dataDrivenPages.pageRow.getValue(queryfield)
print value
if lyr.definitionQuery == True: # if a definitionQuery Exsts...
query = lyr.definitionQuery + "AND" + queryfield + "=" + "\"" + value + "\"" # Add new to old
else:
query = queryfield + "=" + "\"" + value + "\"" # else create a new query
lyr.definitionQuery = query # set the layers defintionQuery
else:
print 'Next' # else print next, this isn't necassary, but its a good place holder
print pageName
arcpy.mapping.ExportToPDF(mxd, pdf) # export the current Page to pdf
del mxd, lyr, pageName, pageNum, query, value
