Merge lines within threshold from Python
368
01-19-2011 05:51 AM
RobinWilson
I have a shapefile with a lot (around 9000) line features in it. Many of these line features are either touching, or very close to touching, and I would like to merge these ones into one feature. Ideally I would then end up with a shapefile with around 50 features in it, each of which would have been merged from the features that were touching.
How should I do this from python? I know I can do it manually from the editor toolbar with the merge tool, but I can't seem to find how to do this programmatically. I've searched in various places and can't seem to find an answer.
Does anyone have any ideas?
NiklasNorrthon
Occasional Contributor III
Maybe the Unsplit Line or the Dissolve tool is what you are looking for.
ChrisSnyder
Regular Contributor III
The Integrate tool?
RobinWilson
Thanks - that looks great.
Is there any difference between the Unsplit Lines tool and the Dissolve tool with the Unsplit Lines checkbox ticked? It doesn't look like there is, but I thought I'd check.
Also, does anyone know a way to do this with distance tolerances too (that is, merging lines that are within a certain distance of another line, instead of having to touch the line).
