I have posted this question previously, but was unable to obtain a definite reply. Hence I am re-posting it once more.
I need to move a set of features based on the XY values from another table linked through table join.
I found a field calculator script (see below), but it was not perfect. This is because the this script can only work if the XY values are within the same table. It does not work with a table join.
Can anyone help to tweak this script or propose an alternative?
def pointMove(shape,x_value,y_value):
point = shape.getPart(0)
point.X = x_value
point.Y = y_value
return point
__esri_field_calculator_splitter__
pointMove( !Shape!, !X!, !Y! )
I am using ArcGIS Desktop 10.2.2.
Thanks!
Regards,
Siyang
