Hi there,What I need to do is move all the files into an mxd to a newly created gdb, chechking prj, and update mxd reference.I have ArcGIS 10 SP4, license ArcViewI studied a bit of Python and get familiar with basic, then I copied some written code and pasted all together, attached is the code.My frustration is that i can???t even move my shp files to a created gdb, is that because of my ArcView license?PLEASE PLEASE PLEASE HELP# Import system modules
import arcpy
from arcpy import env
import os
# Set environment settings
env.workspace = "C:/Users/a391665/Documents/AAAAPERSONALE/rugareto"
# Execute CreateFileGDB
arcpy.CreateFileGDB_management("C:/park", "test4")
# Set local variables
outWorkspace = "c:/park/test4.gdb"
# Use ListFeatureClasses to generate a list of shapefiles in the
# workspace shown above.
fcList = arcpy.ListFeatureClasses()
# Execute CopyFeatures for each input shapefile
for shapefile in fcList:
# Determine the new output feature class path and name
outFeatureClass = os.path.join(outWorkspace, shapefile.strip(".shp"))
arcpy.CopyFeatures_management(shapefile, outFeatureClass)
