I'd love to get some more chatter on this topic...I have been having some great success with getting multiprocessing to work within ArcGIS Pro script tools, but I am still having trouble with Python running in the background, i.e. running without opening a console window.
I implemented the following line of code in my script, just as Kjetil Trengereid suggested, and it works well, except for opening the Python consoles for each pooled process, which I prefer to be hidden.
multiprocessing.set_executable(os.path.join(sys.exec_prefix, 'python.exe'))
I learned that if you use 'pythonw.exe'
that it is meant for GUI python and will not open Python consoles:
multiprocessing.set_executable(os.path.join(sys.exec_prefix, 'pythonw.exe'))
I got this to work very well initially, but now out of the blue, it has started to lock up and stop processing on the first of many multiprocessing functions with no known reason that I can find. It has been stopping during a multiprocess function that has always worked otherwise with python.exe.
In checking the Task Manager, there are some differences with how the multiprocessing programs run on the different executables. When using python.exe, the parallel processes open the Python consoles separately from ArcGIS Pro as completely separate tasks, and when all processes are done, all console windows close, and then if a new multiprocess function is ran later in the code, all new console windows are spawned.
With pythonw.exe, instances show up in Task Manager under the ArcGIS Pro app (you have to click the drop down to see them). What has been happening when things lock up is the CPU column in Task Manager for each instance drops to 0%, the memory shows a value, but goes stagnant. All other columns drop to zero also. Then, the script tool just hangs in ArcGIS Pro and will not progress; the hanging has persisted for hours in one case (overnight...).
I've tried rebooting ArcGIS Pro and my computer to no avail. I also tried using one less CPU than is available and that didn't seem to change anything either.
Is this a memory issue? Task Manager doesn't seem to report anything out of the ordinary and other program will still run. I am working with lidar LAS files; they are not super big by themselves (125 MB or less) but I am doing 40+ files for each multiprocessing function.
Is it an ArcGIS Pro issue? Or a Python code issue? I can share code if needed, but I will need some time to creates generic examples of the code, as the code is proprietary (sorry!!).
I also still have some more experimenting to do. For example, it is a very long, robust script that I could break up into more manageable scripts if needed; not preferable, but doable. I have also not included if __name__ == '__main__':
in my scripts and adding different functions for the multiprocessing parts, which has been a suggestion also. I have created a module for the multiprocessing functions. See Parallel Processing with Python Toolboxes in ArcGIS Pro and arcgis 10.3 - Can multiprocessing with arcpy be run in a script tool? - Geographic Information Syste... for what I mean here.
Any suggestions will be greatly appreciated. Thanks.
