Need Help with Math Operand Error
471
04-25-2013 02:07 PM
ChristopherClark1
Okay I have the following code
 with arcpy.da.UpdateCursor(fc, fields) as rows:
                    for row in rows:
                        row[2] = row[0] * (32.82010551 * 32.82010551) * (0.000000092903)
                        row[3] = (row[1] *(32.82010551 * 32.82010551) * 25)/(row[0] * (32.82010551 * 32.82010551))
                        rows.updateRow(row)
Where I get this error:
PYTHON ERRORS:
Traceback info:
File "G:\Scripts\Threshold_IP_Scripts\GetStreamStatsA.py", line 32, in StreamStatistics
Error Info:
unsupported operand type(s) for *: 'NoneType' and 'float'
ArcPy ERRORS:
Any ideas? I am stuck!
MathewCoyle
You probably have a null value in your row.
This should get you around that.
if row[0]:
    if row[1]:
ChristopherClark1
Sorry I am confused. Where do I put that code?
ChristopherClark1
Is this correct?
 fields = ['RASTERVALU_12', 'RASTERVALU_12_13', 'Cumm_Dr_SQKM', 'Mean_Pr_MM']
                    for row in rows:
                        if row[0]:
                        if row[1]:
                        rows.updateRow(row)
