No module named numpy
2041
11-02-2011 08:33 AM
VadivelanPalanichamy
New Contributor II
I am using ArcGIS Info v10.0 with SP2.  Also, i have installed Python 2.5 and 2.6.
i am getting the "no module named numpy" (Spatial Statistics Tools -> Rendering ->Collect Events With Rendering).
any help on this.
DanPatterson_Retired
Did you rule out the threads listed within a forum search?
http://forums.arcgis.com/search.php?searchid=755128
New Contributor II
Dan
This page is not loading.. i am googled, but i did not get any solution or work around.
thanks,
strange, but try searching the forum on your topic thread (see below), I got numerous links
seria
by Esri Contributor
Please follow the following instructions listed on this Web Page:
Creation of PYTHONPATH Environment Variable
http://mattmakesmaps.com/blog/2013/07/10/fixing-arcgis-10-dot-1-python-console-numpy-import-error/
Just in case you hadn't noticed that the thread is 4 years old
