Not all feature classes updated with Python script
1977
05-03-2016 01:16 PM
MaziziJama
I am experiencing a strange issue, not all the feature classes have been updated when running the following python script in ModelBuilder
The filegeodatabase has a total of 9 feature classes (six of the feature classes have been updated and three are not), no errors are shown in ModelBuilder.
Here is the script I am running:
# Import system modules
import arcpy, os
from arcpy import env
#Set the workspace so that Python knows where to look for the feature classes.
# In this case, it is a GDB
arcpy.env.workspace = r'D:/spatial_data/parcel_data/scratchdb.gdb'
# list the feature classes
fcList = arcpy.ListFeatureClasses()
# loop through list
for fc in fcList:
    #check if field exists, if not, add it and calculate
     if "RegCode" not in arcpy.ListFields (fc):
          arcpy.AddField_management(fc, "RegCode", "TEXT", "", "", field_length = 😎
     if "IdCode" not in arcpy.ListFields (fc):
          arcpy.AddField_management(fc, "IdCode", "TEXT", "", "", field_length = 😎
     if "PNoCreate" not in arcpy.ListFields (fc):
          arcpy.AddField_management(fc, "PNoCreate", "TEXT", "", "", field_length = 😎
     if "PnNoCreate" not in arcpy.ListFields (fc):
          arcpy.AddField_management(fc, "PnNoCreate", "TEXT", "", "", field_length = 5)
     if "IdCreate" not in arcpy.ListFields (fc):
          arcpy.AddField_management(fc, "IdCreate", "TEXT", "", "", field_length = 21)
DanPatterson_Retired
which begs the question... which ones and which field(s) didn't get updated? could it be that a few aren't featureclasses but tables?
MaziziJama
All of them are feature classes.
I am using the script to add multiple fields using the python script.
I have also attached a sample filegeodatabase.
I am only able to add the fields to the Farm_Portion feature class.
to save a download and inspect, did you consider placin a print statement after the listfeature classes to see what was listed and perhaps a print statement after you get a list of the field names to compare to a list of field names as in example 2 in the help topic
ListFields—Help | ArcGIS for Desktop
MaziziJama
I added - arcpy.SetLogHistory(True)
import arcpy, os
The script is running as expected for all feature classes -  all the fields are added.
As to why the script was not executing as expected, I am still not sure of what the problem is.
Thanks Dan for some pointers.
glad to hear it worked out
