Null in python?
26075
06-15-2012 04:29 AM
BartłomiejStaroń
New Contributor III
What is the equivalent of "null" in python to clean the column in calculate field?
I try use "None" ,but without any effect.
DanPatterson_Retired
did you try two double quotes? ""
ChrisBater
New Contributor II
None should not be in quotes.
WilliamIde
New Contributor II
Null What?
None should work for Null pointers
thing is an object.
if  thing == None :
thing is a string
one thing about strings however is users sometimes put man blank charagers in a string. So it looks empty  but "" will fail.  So you need to check thing.len() == 0 first.
if thing == "":
ThaiTruong
Occasional Contributor II
check out this blog for dealing with null values  when using field calculator:
http://blogs.esri.com/esri/arcgis/2010/08/30/concatenate/
# Special case for null soiltype
if soil == '':
    return veg
Basically, you need to convert the value into string even if it's already a string.
