I am having difficulty finding a way that will copy a subset of rows from a table stored in Oracle to a GDB.Here is an example:Source table contains the following fields - "SCHEDULE_TIME", "ADDRESS", "CITY", "STATE", "ZIP_CODE", "ROUTE_ID", "x", "y"I am trying to extract all of the records for a route_id in one zip_code.Here is what I have tried so far:1. The following code ended up copying the entire table to the GDB. strZipCode = "72645" strRouteId = "C024" sqlWhereStmt="\"ZIP_CODE\"='{0}' and \"ROUTE_ID\"='{1}'".format(strZipCode, strRouteId) #MAKE A VIEW OF THE TABLE AND LIMIT THE ROWS BY THE WHERE CLAUSE arcpy.MakeTableView_management("SourceRoute_T", "SourceRoute_V", sqlWhereStmt) #COPY THE TABLE BY USING THE VIEW CREATED ABOVE arcpy.TableToTable_conversion("SourceRoute_V", "C:\\DDT\\Work\\work.gdb", "route_72645C024_T")
2. This following code failed during the call to TableToTable_conversion with an error about the source table not having OIDs The only change is that the where clause has been moved to the TableTable_conversion function. strZipCode = "72645" strRouteId = "C024" sqlWhereStmt="\"ZIP_CODE\"='{0}' and \"ROUTE_ID\"='{1}'".format(strZipCode, strRouteId) #MAKE A VIEW OF THE TABLE AND LIMIT THE ROWS BY THE WHERE CLAUSE arcpy.MakeTableView_management("SourceRoute_T", "SourceRoute_V") #COPY THE TABLE BY USING THE VIEW CREATED ABOVE arcpy.TableToTable_conversion("SourceRoute_V", "C:\\DDT\\Work\\work.gdb", "route_72645C024_T", sqlWhereStmt)
