I have a script that writes .dbf files to a folder. The first time the script runs it does what it is supposed to. The second time I run it however, it says the first .dbf to be created already exists and stops. It's not overwriting the files.
I have arcpy.env.overwriteOutput = True and had it successfully working to overwrite at one point in the development of the script. I'm not sure what made it stop working. I'm pretty sure I added the field mapping and the listing of the files in the log file after it was running smoothly but, have commented them out and it still gives me the error message. Any suggestions would be appreciated....I have no idea what is causing the problem.
# Import arcpy module import arcpy, sys, traceback, time, datetime, os # Set overwrite option arcpy.env.overwriteOutput = True # INPUT NEEDED: Set Read me file workspace CURDATE = datetime.date.today() logpath = "X:\\Script\Out\ReadMe" logfile1 = logpath + str (" ") + str(CURDATE) + ".txt" if arcpy.Exists(logfile1): arcpy.Delete_management(logfile1) log1 = open(logfile1, "a") print "Generate Readme file " + str(CURDATE) print >> log1, time.strftime("%c") print >> log1, "End Processing " #Set the current workspace for input file geodatabase arcpy.env.workspace = "X:\\Script\Input.gdb" #Set Local variables specifyting the output table folder: outTable = "X:\\Script\Out" print "Start Processing" #Set a Search Cursor on the Polygons srows = arcpy.SearchCursor("Polygons", "","", "WATERSHED", "" ) srow = srows.next() print "Get Polygon" mapFields = ["ID", "STUDY", "NAME"] fieldMappings = arcpy.FieldMappings() for mapField in mapFields: fieldMap = arcpy.FieldMap() fieldMap.addInputField("Points", mapField) fieldMappings.addFieldMap(fieldMap) while srow: pid = srow.ObjectID poly_lyr = arcpy.MakeFeatureLayer_management("Polygons",'pgon_select',""" "ObjectID" = """+ str(pid)) print "Watershed is " + str(srow.WATERSHED) arcpy.MakeFeatureLayer_management("Points", "Points_lyr", "", "", ) print "Make point feature layer" arcpy.SelectLayerByLocation_management("Points_lyr", "INTERSECT", "pgon_select", "", "NEW_SELECTION") print "Select points by " + str(srow.WATERSHED) + " watershed" arcpy.TableToTable_conversion("Points_lyr", outTable , str(srow.WATERSHED)+ ".dbf","") print "Make table " + str(srow.WATERSHED) srow = srows.next() print "Next Polygon" print "Write .dbf tables to log file" print >> log1, "Files generated = " file_list = os.listdir(outTable) for file in file_list: if file.endswith (".dbf"): log1.write(file + "\n") print "End Processing" log1.close()
You have neglected to close the cursor when you are done. You must do this, otherwise the cursor stays open -- and you may run into file locking on the next run.del srows
Also, using a layer object ("Polygons") with a tool that is attached to an open cursor (outside of directly accessing the geometry or actions like that) is generally bad practice as you are accessing the dataset from two objects at the same time.I think it is much safer to create a list of unique watershed ids first, closing the cursor and then looping on that list.Note the "for" loop construct below. This is the best way to loop through cursors in arcpy (until 10.1 when you should use arcpy.da).#Set a Search Cursor on the Polygons srows = arcpy.SearchCursor("Polygons", "","", "WATERSHED", "" ) sheds= list() for srow in srows: sheds.append(srow.WATERSHED) del row,srows # close/delete cursor variables for shed in sheds: ... arcpy.MakeFeaturelayer_management('"WATERSHED" = \'' + shed + "'"...) ...
Hope this helps.
