Performance problems in desktop 10.3.1?
5092
7
05-19-2015 09:30 AM
DennisMurphy
I am experiencing performance delays in 10.3.1 - on the simplest tasks.
Loading basic tools will take minutes, with a message of "Not Responding" displayed.
Any other reports of this issue with Desktop release?
curtvprice
Whenever I do an upgrade, I always take the time to  Resetting your ArcGIS application profile​. Have you?
DennisMurphy
Thanks for the suggestion.
I reset my application profile; Desktop Arcmap still is sluggish and I get
the message "Not responding"
DennisMurphy
Looks like the problem source is a corrupt mxd file.
curtvprice
LukeSnyder
I've just finally upgraded to 10.3.1...... and am experiencing very sluggish performance with creating, selecting, and editing all features. I've run the defrag utility with no benefit.
I was running 10.2 last Friday (Nov. 6, 2015) with zero issues.
Have you found a solution?
curtvprice
Whenever I update I reset my profile, and often try to work with a fresh MXD if I can.
LukeSnyder
Thanks Curtis. I did create a new MXD as I continued to troubleshoot. Worked perfectly...except when adding Group Layers. I can duplicate 5 data layers and continue to function perfectly. If I put those same 5 layers in a Group Layer, performance becomes extremely sluggish again with/without the layers being displayed.
