Plotting a Spatially Enabled DataFrame w/ datetime column with all NaT values causes exception
968
07-30-2019 01:46 PM
JimmyKnowles
Occasional Contributor II
This isn't really a question since this might be the expected behavior, but since I spent a good chunk of time pinpointing the problem, figured I'd share.
I was playing around with SEDFs and had some issues plotting a SEDF that had NaT datetime values. The error it gave was
  • AttributeError: Can only use .str accessor with string values, which use np.object_ dtype in pandas
This seems to only be an issue if all the values in a datetime column are NaT. I won't go into details why, but there was a datetime column that didn't have a single valid datetime value, all values were null/NaT.
So, the following line of code was causing the error
sdf.spatial.plot(map_widget=m1)‍‍‍
BjørnSteen
Thank you for posting this.   I expired the same thing but with anoter columns.  IAnd 'I have struggeled a lot until I find this post.
BjørnSteen
Experienced
