populate x,y
4946
17
07-29-2015 02:30 PM
PacoAlverez
New Contributor III
I am trying to populate ever point's x,y when a point is created by a mouse click or clicking. Some times i might only create one point but sometimes i may have to create more then one. I am having trouble populating the x,y of the new created points.
this is currently what i have. I know it's wrong. i would like to see how to do this correctly.
getting error at
  File "C:\GIS\Python\AddPoint\AddPoint_4.py", line 18, in <module>
    geom = prow.SHAP
AttributeError: 'tuple' object has no attribute 'SHAPE'
Failed to execute (Script).
#import modules
import arcpy
arcpy.env.qualifiedFieldNames = False
pointFC = "Animal Sightings" #target point feature class Animal Sightings
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
dfsr = df.spatialReference
fcsr = arcpy.Describe(pointFC).spatialReference
if dfsr.name == fcsr.name:
    """Now do your work"""
point = arcpy.GetParameterAsText(0)  #click
for prow in arcpy.da.SearchCursor(point,'SHAPE@XY'):
        x,y = prow[0]
        geom = prow.SHAPE
        prow.x = geom.X
        prow.y = geom.Y
del prow
insCursor = arcpy.da.InsertCursor(pointFC,('POINT_X','POINT_Y','SHAPE@XY')) # create insert cursor
with arcpy.da.SearchCursor(point,('POINT_X','POINT_Y','SHAPE@XY')) as cursor: # loop through feature set
    for row in cursor:
        POINT_X = row[0]
        POINT_Y = row[1]
        insCursor.insertRow(row) # insert row
del insCursor # delete insert cursor
DarrenWiens2
MVP Honored Contributor
Okay, last reply, then you're going to have to piece some of this together on your own.
insCursor = arcpy.da.InsertCursor(pointFC, ['Minrights', 'FCVTotal','POINT_X','POINT_Y','SHAPE@XY']) # create insert cursor
with arcpy.da.SearchCursor(point,['Minrights', 'FCVTotal','POINT_X','POINT_Y','SHAPE@XY']) as cursor: # loop through feature set
    for row in cursor:
        row[0] = row[0] # if the 'Minrights' value is coming from the search cursor, otherwise change this
        row[1] = row[1] # if the 'FCVTotal' value is coming from the search cursor, otherwise change this
        row[2] = row[4][0] # the X coordinate from the SHAPE@XY
        row[3] = row[4][1] # the Y coordinate from the SHAPE@XY
        row[4] = row[4] # the whole SHAPE@XY
PacoAlverez
New Contributor III
Darren. thank you for your time and responses. i apologize for my python skills are not so great.
JoshuaBixby
MVP Esteemed Contributor
Since Arcpy Data Access search cursors return tuples, this specific code will generate a TypeError since tuples don't support item assignment.
PacoAlverez
New Contributor III
Hi Joshua. I was trying to understand how to create a point or multiple points and how those new points attributes populated from the parcel the new points are within. The x,y would be calculated at the time the new point or points are created.  I am rather new to python so my first posted code was based on information i found.
JoshuaBixby
Unless you are willing/able to post a subset of the data and a description of what the final product would look like, I am out of ideas.  Best of luck.
PacoAlverez
New Contributor III
Here is some data. thanks for your help.
JoshuaBixby
What is point, exactly?  Your code is  point = arcpy.GetParameterAsText(0)  # click , but I am unclear what is being returned.  Is point supposed to be an ArcPy Point object or a set of coordinates for a location or a name to a feature class containing points?
Regarding your original error message, just so you understand why you were getting that error, you were using the SHAPE@XY token.  The SHAPE@XY token returns a Python tuple of the x,y coordinates of the point, not an ArcPy Point object or PointGeometry object.  As such, there is no 'SHAPE' attribute so an AttributeError is generated.
JoshuaBixby
Are POINT_X and POINT_Y populated in point or are they going to be new data in pointFC?  If they are NULL in point, why are you retrieving them with the search cursor?
In cases like this, posting some sample data and an explanation of what you are trying to accomplish is helpful.  It could be your entire approach is off, and people in GeoNet could offer a different way of doing it entirely.
