I am trying to populate ever point's x,y when a point is created by a mouse click or clicking. Some times i might only create one point but sometimes i may have to create more then one. I am having trouble populating the x,y of the new created points.
this is currently what i have. I know it's wrong. i would like to see how to do this correctly.
getting error at
File "C:\GIS\Python\AddPoint\AddPoint_4.py", line 18, in <module>
geom = prow.SHAP
AttributeError: 'tuple' object has no attribute 'SHAPE'
Failed to execute (Script).
#import modules
import arcpy
arcpy.env.qualifiedFieldNames = False
pointFC = "Animal Sightings" #target point feature class Animal Sightings
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
dfsr = df.spatialReference
fcsr = arcpy.Describe(pointFC).spatialReference
if dfsr.name == fcsr.name:
"""Now do your work"""
point = arcpy.GetParameterAsText(0) #click
for prow in arcpy.da.SearchCursor(point,'SHAPE@XY'):
x,y = prow[0]
geom = prow.SHAPE
prow.x = geom.X
prow.y = geom.Y
del prow
insCursor = arcpy.da.InsertCursor(pointFC,('POINT_X','POINT_Y','SHAPE@XY')) # create insert cursor
with arcpy.da.SearchCursor(point,('POINT_X','POINT_Y','SHAPE@XY')) as cursor: # loop through feature set
for row in cursor:
POINT_X = row[0]
POINT_Y = row[1]
insCursor.insertRow(row) # insert row
del insCursor # delete insert cursor
