I'm trying to add a list of coordinates to a feature class in arcpy. When I manually add each xy pair as graphics into arc map using the go to xy tool, the points show up where I expect them to:
However, when I use arcpy, they are slightly offset:
Here is the code I'm using:
<code>
import arcpy, json, ConversionUtils
arcpy.Delete_management("in_memory")
coordinates = [
[-118.3436607214932, 34.18465195557297],
[-118.3437040116469, 34.18108463923645],
[-118.338436218283, 34.18097397459129],
[-118.3383716114292, 34.18454551218532],
[-118.3421286432001, 34.18221218702963],
[-118.3398871274149, 34.18236566520285]
feature_class = arcpy.CreateFeatureclass_management("in_memory", "temp_feature_class", "POINT")
cursor = arcpy.da.InsertCursor(feature_class, ['SHAPE@'])
points = []
for (x, y) in coordinates:
points.append(arcpy.Point(x, y))
for point in points:
cursor.insertRow([point])
sr = arcpy.SpatialReference(4326)
arcpy.DefineProjection_management(feature_class, sr)
arcpy.FeatureClassToShapefile_conversion(feature_class, "C:/Temp")
</code>
Is anyone able to reproduce this problem, and if so, what is causing it and what can I do to fix it.
Jason
