Things are slow right now at work so I found an answer to the second part of this question: how to get the file geodatabase table/feature class size. In Snippets.py, underneath the GetModifiedDate function, insert:
def GetFileSize(gdb, tableName, featureDataset):
# Define a function which will convert bytes to a meaningful unit
def convert_bytes(bytes):
bytes = float(bytes)
if bytes >= 1099511627776:
terabytes = bytes / 1099511627776
size = '%.2f TB' % terabytes
elif bytes >= 1073741824:
gigabytes = bytes / 1073741824
size = '%.2f GB' % gigabytes
elif bytes >= 1048576:
megabytes = bytes / 1048576
size = '%.2f MB' % megabytes
elif bytes >= 1024:
kilobytes = bytes / 1024
size = '%.2f KB' % kilobytes
else:
size = '%.2 fb' % bytes
return size
# Setup
GetStandaloneModules()
InitStandalone()
import comtypes.gen.esriSystem as esriSystem
import comtypes.gen.esriGeoDatabase as esriGeoDatabase
import comtypes.gen.esriDataSourcesGDB as esriDataSourcesGDB
# Open the FGDB
pWS = Standalone_OpenFileGDB(gdb)
# Create empty Properties Set
pPropSet = NewObj(esriSystem.PropertySet, esriSystem.IPropertySet)
pPropSet.SetProperty("database", gdb)
# Cast the FGDB as IFeatureWorkspace
pFW = CType(pWS, esriGeoDatabase.IFeatureWorkspace)
# Get the info for a stand-alone table
if featureDataset == "standalone":
# Open the table
pTab = pFW.OpenTable(tableName)
# Cast the table to an IDatasetFileStat object
pDFS = CType(pTab, esriGeoDatabase.IDatasetFileStat)
# Return the size
return convert_bytes(pDFS.StatSize)
else:
# Open the feature class
pTab = pFW.OpenFeatureClass(tableName)
# Cast the table as a IDatasetFileStat
# Return the size
It's very similar to the GetModifiedDate function, but uses a different property of the IDatasetFileStat object.
...Really though, this information ought to be accessible via something like
arcpy.Describe().modifiedDate
arcpy.Describe().fileSize
